KOnahic Posted June 24, 2021 Posted June 24, 2021 Hey Y'all, I'm having a small garage sale. I have the following parts for sale: Ford Crossflow Autolite distributor with Pertronix module, slightly used cap. Comes with a second Pertronix module, a used cap & Pertronix Flamethrower coil. I got tired of fighting it every time I set the timing & the plug wires got hung up on the bottom of Weber carbs. $225 Facet 12V Electric Fuel Pump, AN6 fittings on both sides. New $55 Holley Fuel Pressure regulator New $25 Used 6qt. Oil Tank. I thought it was leaking & tried sealing the bottom with J/B Weld. It wasn't the tank. Comes with the necessary AN fittings. $150 2) Lotus Nose badges. New, still in the box. $50 ea. I have some leftover bits from installing a Tilton Pedal assembly. $5 just to cover the time it'll take me to box them. Buyer to pay the shipping. Everything except the oil tank will fit into a USPS "if it fits, it ships" box. As long as you're in the US, it'll work, elsewhere in the world I will help you find the least expensive way to get it to you. Thanks for looking, Kurt 768D4B33-AE4C-4C33-B0C5-2A89F12C384A_1_201_a.heic 3BE2E5DF-0FA5-4861-9006-6755E0C131A8_1_201_a.heic D28A6844-8E6F-45BD-B9D9-C90B5936E054_1_201_a.heic A697F740-A8CA-4A41-8011-104C3A5E19D4.heic 7C232803-3C42-4ABE-BD8D-0EBA0050587B_1_201_a.heic
Gto7419 Posted June 25, 2021 Posted June 25, 2021 Hey, What tilton parts do you have leftover? After test driving my car it appears I need to reengineer my throttle pedal
KOnahic Posted June 25, 2021 Author Posted June 25, 2021 Just the stuff that comes with the master cylinders to mount the reservoirs on the firewall. Its what is shown in the picture. Kurt
Gto7419 Posted June 26, 2021 Posted June 26, 2021 Ah. Thanks for the reply. Pics aren't showing for me. I'm all settled with brakes. Good luck
JohnCh Posted June 26, 2021 Posted June 26, 2021 Not sure why your photos are attaching that way. They are uploading as .heic files which is an Apple-specific image file format, but when testing an upload from my iPhone which is set to that format, images work correctly. You may want to try again or save the photos as a .jpeg first, or PM me and I'll see if I can help. -John
KOnahic Posted June 26, 2021 Author Posted June 26, 2021 John, Thanks for the heads up. I'll work on changing them to JPEG format. Thanks, Kurt
KOnahic Posted June 26, 2021 Author Posted June 26, 2021 Hey Y'all, My bad...here's some pictures you can actually look at. Thanks for staying on top of things John. Kurt
aidanparte Posted June 29, 2021 Posted June 29, 2021 What did you replace the Autolite/Pertronix setup with?
KOnahic Posted June 30, 2021 Author Posted June 30, 2021 I replaced it with the complete distributer that Pertronix sells. The plug wires come out the side rather than the top. If they come out of the top, they hit the bottom of the front carb; if you're running 2 Webers. Kurt
s2europa Posted August 11, 2021 Posted August 11, 2021 What are the dimensions of the oil tank? Can you post a picture of the JB Weld area? Thanks!
KOnahic Posted August 11, 2021 Author Posted August 11, 2021 Here's a couple of pictures for you of the end I used the JB weld on. It could probably be sanded or filed to make it a little smoother. Its 6 1/2" across & 14 1/2" tall. I hope this helps, Kurt
KOnahic Posted September 24, 2021 Author Posted September 24, 2021 Sorry guys/gals, everything has been sold.
