Anyone know where I can purchase a traditional Super Seven front grill emblem?  These are typically laser-cut steel (preferably stainless), and feature the outline of a large "7" measuring about 7.5" tall and about 8" wide.  The digit is surrounded by a halo of steel, as in the image below.  Let me know if you have access to supply.  Thanks!
I'd recommend https://sendcutsend.com/ for something like that. You'll need the artwork, which I've attached, scaled to 7.5 wide x8 tall. They'll be able to cut it from nearly any material you want.
Lotus 7 Logo.eps
I just used the design that cmoist posted to have an emblem cut, it came out perfectly from sendcutsend see pic below. Thankyou cmoist!
I hand cut and filed a piece of aluminum plate , didn't take all that long and you can custom size it
@cmoist Thanks for posting the file and for the sendcutsend recommendation.  I'm sure that I'll use them for something, if not an emblem.  What thickness do you recommend for the emblem in stainless?
  • 3 weeks later...
