Dwight Posted July 21, 2021 Posted July 21, 2021 For the purpose of reviewing a schematic diagram for bearing maintenance, etc., what front hub/brake assembly would a 2001 S3 model have used? Dwight
yellowss7 Posted July 21, 2021 Posted July 21, 2021 https://caterhamparts.co.uk/hubs-and-bearings/620-wheel-bearing-kit-front-pre-2003-cars.html https://caterhamparts.co.uk/hubs-and-bearings/116-hub-front-aluminium-41-4-pcd-ford-pre-2003.html that is assuming prior owner did not do the upgrade which included a thicker stub axel as well as stronger hub and different bearings.
dallasdude Posted July 23, 2021 Posted July 23, 2021 yellowss7 is exactly right about the upgrade. The non updated parts are all Spitfire, readily available from Moss Motors. Bearings, seal, rotors. The updated assembly is easily recognizable as it has a large exposed nut on the end of the spindle (no cap). Both the inner and outer bearings with the update have a lip seal, and are very commonly used in Europe on trailers (caravans). Exactly same bearing is common for trailers in the US, but without the lip seal which is necessary for this setup.
