mrmustang Posted October 22, 2021 Posted October 22, 2021 I've installed the Caterham spec wet sump pan on my 1.6L Sigma engine, from what I can now see, I've now uncovered two extra bolt holes for the Caterham pan to bellhousing that for my sanity, I need to add bolts to, even though the stock pan did not use these bolt holes. I am thinking 1.5" in in length, but I am uncertain of the thread pitch as I am not with the car at the moment, can anyone assist? In addition, can someone confirm oil capacity at 4 quarts, I vaguely remember 3.8-4L as being the capacity, but there is no real paperwork with the pan as delivered by Caterham, UK. Thanks in advance, Bill S.
11Budlite Posted October 23, 2021 Posted October 23, 2021 Bill - The pan bolts should be 8 x 1.25 x 35mm long. Not sure of oil capacity because I haven't changed the oil yet, but it should be right around 4 qts.
mrmustang Posted October 23, 2021 Author Posted October 23, 2021 23 minutes ago, 11Budlite said: Bill - The pan bolts should be 8 x 1.25 x 35mm long. Not sure of oil capacity because I haven't changed the oil yet, but it should be right around 4 qts. Bruce, Thanks, I confirmed with Caterham UK that the 3.8-4L is correct, this is just a hair over 4 quarts US, so I am good to go there. Also appreciate the bolt size, when I am back in town I'll be able to get those two vacant holes filled with the proper bolts, which will make my ADHD brain happy. Bill S.
11Budlite Posted October 23, 2021 Posted October 23, 2021 Glad I could help Bill. And I found one source that said the oil pan bolts should be torqued to 15 lb-ft and that's what I used when I reinstalled the bolt.
