papak Posted November 4, 2021 Share Posted November 4, 2021 I am considering switching from Brooklands windscreens to a moulded aeroscreen on my Birkin. Could I trouble any of you with an S3/CSR for the dimension across the scuttle between the lower windscreen stanchion mounting points? Basically the width of the scuttle at that point. Thanks Link to comment Share on other sites More sharing options...
Croc Posted November 4, 2021 Share Posted November 4, 2021 @papak Just to clarify - do you need an S3 (original width) or an S5/SV/CSR (wider chassis width)? Link to comment Share on other sites More sharing options...
Kitcat Posted November 4, 2021 Share Posted November 4, 2021 (edited) Papak. If you are trying to see if the Caterham aeroscreen fits a Birkin, I can confirm it does not. Ditto a Caterham standard windscreen. I owned both a S3 Cat and standard Birkin at the same time for a while. I had a Caterham issued Brooklands set up that I tried to fit to my Birkin. It wasn’t close. The shapes of the cowls, while visually similar, are actually very different. Edited November 4, 2021 by Kitcat Link to comment Share on other sites More sharing options...
papak Posted November 4, 2021 Author Share Posted November 4, 2021 (edited) Thanks. I was hoping that the wider scuttle fitment might work. I misspoke in my initial post. I am looking for the dimension of the wider scuttle, SV/CSR. If this doesn't work, I'll probably make a mold and lay one up myself. Edited November 4, 2021 by papak Link to comment Share on other sites More sharing options...
