A dimension needed
papak
I am considering switching from Brooklands windscreens to a moulded aeroscreen on my Birkin. Could I trouble any of you with an S3/CSR for the dimension across the scuttle between the lower windscreen stanchion mounting points? Basically the width of the scuttle at that point. Thanks
Papak. If you are trying to see if the Caterham aeroscreen fits a Birkin, I can confirm it does  not. Ditto a Caterham standard windscreen. I owned both a S3 Cat and standard Birkin at the same time for a while. I had a Caterham issued Brooklands set up that I tried to fit to my Birkin. It wasn’t  close. The shapes of the cowls, while visually similar, are actually very different.
Edited by Kitcat
Thanks. I was hoping that the wider scuttle fitment might work. I misspoke in my initial post. I am looking for the dimension of the wider scuttle, SV/CSR. If this doesn't work, I'll probably make a mold and lay one up myself.
Edited by papak
