Bellhousing Dry Sump
Source
 Share
Hey guys. I found someone local to diagnose and work on my recently bought car since I don't really have the space to do so at the moment. He seems to have narrowed the oil leak down to between the bellhousing and the block, but doesn't know exactly where in there it's coming from. He hasn't worked on sevens before so he is unfamiliar with the different drivetrains. He is asking if I have a diagram or schematic or anything that he can look at or a parts list. I am unfamiliar with the car as well so I don't really have that information or know enough about it. I have all the service records and original build manual but it doesn't go in depth on the dry sump and the bell housing holding the engine oil. I assume it's a gasket somewhere in there but he can't see one.
Any information you guys can provide or a direction to point me in so I can tell him is appreciated.
Car information:
1994 Caterham Super 7 HPC
Vauxhall C20XE w/ Swindon internals
Ford Type 9 gearbox
Dry sump in the bell housing
Thanks
I am going to assume it is engine oil and not transmission fluid?
Second, do you know it is dry sump tank leaking or maybe a rear main seal on the Vauxhall engine?  Rear main seal is more common than a dry sump tank leaking.  The bellhousing dry sump tanks will usually leak straight away at first use or just be leak free for eternity.
Third, which type of bellhousing dry sump?  There were two.  The later Titan produced kind as used for 1995 to 2015 area is shown in photos below.  There was a version used in the Rover K series and adapted to the later Duratec.  Is this your type?  I dont think so but want to confirm to be sure.
CIMG1199_edited-1.JPG.effd01092b0c36618bebfe7314ed120d.JPGIMG_5798.thumb.jpg.13c71b6a22e30f769226579d6ba1e876.jpgIMG_5799.thumb.jpg.6c9f1acb8579b8dc99ce76639b143cbf.jpg
I have only seen the earlier type of vauxhall dry sump within bellhousing once before - yours is the only one I have heard of its type in the USA.  No photos sorry.  It had a different swirl tower.  No idea on the internals.
Sadly, the solution for either type of leak is to pull the engine.
For diagrams - have you checked the downloads section of this site for the available technical literature?  Link here
Downloads - USA7s
Hey Croc. Thanks for the reply. My original thought and the thought of the previous owner is that it's the rear main seal that is leaking. It is indeed engine oil that is leaking. There is gear oil leaking too but those have been identified and fixed. The engine oil is the main one we are trying to figure out.
Sadly, I really don't know anything about the drivetrain in this car. All I know is what I can see in the paperwork he has given me. And there's not much information in there. And this is my first Caterham. I'm still learning all of what is going on and I've had trouble finding information online about the HPC cars. I know someone else who has one but ours are fairly different. So honestly I don't have a clue what dry sump is in the car. I'll forward the information you've given me to my friend that is working on the car.
If you are looking for useful technical information on the Vauxhall engine, then SBD has a very good section here:
Vauxhall Instruction Sheets | SBD Motorsport
For parts your main options are in the UK - QED, Redline and SBD Motorsports.
A relevant post on L7C that feels somewhat close to your symptoms is here:
Crank oil seal change - which parts and where to buy? | Caterham and Lotus Seven Club (caterhamlotus7.club)
I know an experienced long-term owner with a VX engine so can reach out to him once you have pulled the engine and worked out where the source of the leak(s) are.
@SourceI have a very similar car to yours.  The original owner actually ordered the kit from Caterham to install the bell housing dry sump, but never installed it.  I have it, new in a box.  Someone was kind enough to email me an installation document and this may help you with your system.  Here you go...
Vauxhall Dry Sump System_master.doc
Wow, thanks for this. It's been hard finding information about this car on the internet. I'm glad to know another person that has a similar car. That way we can compare some notes here and there.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
