Is this clutch bearing defective?
IamScotticus
6 hours ago, Vovchandr said:
IMO Cost benefit analysis isn't there to try to reuse any questionable part.
Its a new part, I neglected so it got rust on it.
Anyone have a Ford part number?  none on the item.  Box is not Ford.
2 hours ago, 7Westfield said:
I have a spare   it's the SKF from Burton   ECB113
I'm not going to use it--went hydraulic
$30 shipped?
looks like SKF number is VKC 2144
sure
PM you later
sure, PM you later
Edited by IamScotticus
On the subject of release bearings,
When I set up my cable play, I have the option of preloading the bearing.  This has been discussed elsewhere,  with the opinion that keeping a light contact with the splines, thus keeping the bearing moving,  helps reduce bearing face wear on the take-up.
Any experience with this?
T-9 to Xflow
