this is a CRB for a Ford Merkur or 2000, whatever..
Supposed to be the thing for the T-9.
It appears the inner sleeve is off center.
Yes, there is rust,  but otherwise,  is this CRB usable?
the spare I have (new)  doesn't have that slop
it's out, and they're cheap.......
Edited by 7Westfield
6 hours ago, Vovchandr said:
IMO Cost benefit analysis isn't there to try to reuse any questionable part.
Its a new part, I neglected so it got rust on it.
Anyone have a Ford part number?  none on the item.  Box is not Ford.
I have a spare   it's the SKF from Burton   ECB113
I'm not going to use it--went hydraulic
$25 shipped?
looks like SKF number is VKC 2144
$30 shipped?
sure
PM you later
sure, PM you later
Edited by IamScotticus
On the subject of release bearings,
When I set up my cable play, I have the option of preloading the bearing.  This has been discussed elsewhere,  with the opinion that keeping a light contact with the splines, thus keeping the bearing moving,  helps reduce bearing face wear on the take-up.
Any experience with this?
T-9 to Xflow
I had cable with my T-3.  I left it loose, basically just the weight of the pedal when at rest
it may also depend on pedal height you want
