drewbrese Posted July 21, 2022 Share Posted July 21, 2022 (edited) THIS… unique 1978 Caterham Seven features a turbocharged Lotus twin cam engine and exemplifies the thrill of driving. Links to forum albums for pictures album 1, album 2, album 3, and driving video. Engine Built by William’s Racing in Harvard, MA 2.0 L, 300 hp, 289 lb-ft, 14 psi boost, 8.4 compression ratio Jennings aluminum block with iron liners CP-Carrillo rods and pistons Marine forged crank shaft Dave Bean camshafts Dry sump oil tank Water to air intercooler under hood with rear mounted radiator, reservoir, and pump Jenvey 70 mm throttle body and custom machined aluminum intake manifold Garrett turbocharger Custom stainless steel exhaust manifold with heat shielding Tial MVS external wastegate Aluminum radiator AEM UEGO sensor Haltech Platinum Sport 2000 ECU Oil, oil filter, and engine coolant changed in 2022 Currently the car is conservatively tuned to approximately 235 whp to maximize longevity and durability Previous owner had this engine built so the information above is from conversations I had with William’s after purchasing the car as well as the owner’s listing Transmission 5 speed manual Quaife box built by Parks Transmission Tilton OT-II 7.25 twin plate clutch and lightweight flywheel Close ratios, geared for 140 mph at 6000 rpm Clutch master and slave cylinders replaced in 2021 Clutch recently started slipping Chassis Caterham S3 with live axle Nitron NTR1 one-way adjustable dampers from Meteor Motorsports in 2019 Front suspension bushings, tie rod ends, and rear trailing arm bushings replaced in 2019 Rebuilt front brakes with new Girling master cylinder in 2019 Rear shoes and wheel cylinders replaced in 2019 Original 13” wheels refinished in 2018 Pirelli Cinturato CN36 185/70R13 tires new in 2020 Changed rear differential oil in 2022 Everything Else Unpainted aluminum body panels with aluminum S1 styled nose cone, front and rear fenders Panels are in OK condition, passenger side rear fender was dented by some road debris, the are plentiful rock chips in the usual places and other imperfections commonplace for a 44-year-old car, however most the panels can be polished to a mirror like finish. New aluminum fuel tank and fuel filter in 2019 Standard windshield with side mounted wind deflectors Carbon fiber aero screen with carbon fiber side and center mirrors can be included JW Speaker 8631 LED headlights with integrated turn signals, daytime running lights, parking lights, high beam, low beam mounted in black 5 inch Caterham housings LED taillights with both stop and turn signal functions Moto-Lita leather steering wheel with quick release Custom upholstered tonneau cover Fire extinguisher Some original parts and spares will be included such half doors and hood Currently registered and located in Lexington, Massachusetts with a clean title 30,106 miles on the odometer I’ve enjoyed driving and wrenching on this Caterham since I purchased it in 2018. I was not prepared for the reactions it gets from folks when I’m out for a drive, as if they’ve just seen a UFO. It’s Matchbox like dimensions and lightness make it one of the quickest cars for my local twisty and tight roads. Great handling combined with giggle inducing turbo power make this car unique even among other Sevens. This Spring I was getting ready to sell the car and noticed something wasn’t quite right, the clutch is slipping. Replacing the clutch isn’t particularly challenging but it is resource consuming, and after ruminating on what to do I have decided to sell the car as is instead of letting it sit. Sold. Edited October 17, 2022 by drewbrese Sold. 1 Link to comment Share on other sites More sharing options...
spitfun Posted July 22, 2022 Share Posted July 22, 2022 Looks like a great car,if it's not a scam someone should be all over this. I would be if I didn't just buy the SuperFormance S1... GLWS Link to comment Share on other sites More sharing options...
drewbrese Posted July 22, 2022 Author Share Posted July 22, 2022 34 minutes ago, spitfun said: Looks like a great car,if it's not a scam someone should be all over this. I would be if I didn't just buy the SuperFormance S1... GLWS HA! Not a scam. Link to comment Share on other sites More sharing options...
spitfun Posted July 22, 2022 Share Posted July 22, 2022 No offense implied,seems like a very good price... Should sell quickly. 1 Link to comment Share on other sites More sharing options...
IamScotticus Posted July 22, 2022 Share Posted July 22, 2022 Pics! Im not a buyer😒 Link to comment Share on other sites More sharing options...
drewbrese Posted July 22, 2022 Author Share Posted July 22, 2022 10 hours ago, IamScotticus said: Pics! Im not a buyer😒 I put links to albums in the second line of the listing. Let me know if they don't work. Link to comment Share on other sites More sharing options...
JB455 Posted July 22, 2022 Share Posted July 22, 2022 Absolutely beautiful car! Impressive power from the Twin Cam! Even more so- the torque! Must be a blast to drive. What part of MA are you in? Was up south of Boston yesterday, caught a glimpse of a Super Seven in the showroom of Joseph's Garage in Norwell. Stopped for a closer look- I asked if it was for sale and was told that it was Steven Tyler's and not for sale. Link to comment Share on other sites More sharing options...
TMRL7 Posted July 26, 2022 Share Posted July 26, 2022 Very interesting car! I had the opportunity to see it in person last fall. 1 Link to comment Share on other sites More sharing options...
Nordschleife Posted July 30, 2022 Share Posted July 30, 2022 (edited) That's a stunner. Do you happen to know the weight? Edited July 30, 2022 by Nordschleife Link to comment Share on other sites More sharing options...
drewbrese Posted July 30, 2022 Author Share Posted July 30, 2022 11 hours ago, Nordschleife said: That's a stunner. Do you happen to know the weight? Previous owner believed it was about 1200 lbs. I have not weighed it. Link to comment Share on other sites More sharing options...
Cueball1 Posted August 7, 2022 Share Posted August 7, 2022 Possible to post additional interior pics? None show seats or interior finishing well. Link to comment Share on other sites More sharing options...
drewbrese Posted August 9, 2022 Author Share Posted August 9, 2022 On 8/7/2022 at 5:40 PM, Cueball1 said: Possible to post additional interior pics? None show seats or interior finishing well. Added an additional album with some interior pictures. Seats are in great shape, there aren't any tears in the vinyl. Album 3 Link to comment Share on other sites More sharing options...
JB455 Posted August 9, 2022 Share Posted August 9, 2022 Can the trans be pulled out without removing the motor? Or at least moved far enough back to get to the clutch? Doing a clutch is no big deal, but removing that motor with all of the turbo piping and EFI stuff looks a little daunting. 😳 Link to comment Share on other sites More sharing options...
drewbrese Posted August 10, 2022 Author Share Posted August 10, 2022 9 hours ago, JB455 said: Can the trans be pulled out without removing the motor? Or at least moved far enough back to get to the clutch? Doing a clutch is no big deal, but removing that motor with all of the turbo piping and EFI stuff looks a little daunting. 😳 I don't know if you can separate the two and slide them apart enough while still in the car to change the clutch. Removing the engine and transmission isn't daunting and no special tools are required other than a hoist preferably with a load leveler, Link to comment Share on other sites More sharing options...
Cueball1 Posted August 10, 2022 Share Posted August 10, 2022 (edited) Oops. In OP. NVM Edited August 10, 2022 by Cueball1 Link to comment Share on other sites More sharing options...
drewbrese Posted August 14, 2022 Author Share Posted August 14, 2022 Driving video. 1 Link to comment Share on other sites More sharing options...
rnr Posted August 26, 2022 Share Posted August 26, 2022 I wonder if it would be possible to register this car in CA. Do you have any pictures of the original build? Or history of how it was registered from 1978 onwards California DMV will ask for proof of it being assembled as a kit car. Link to comment Share on other sites More sharing options...
Cueball1 Posted August 26, 2022 Share Posted August 26, 2022 Was the built turbo motor installed day one or is it lower miles than the chassis? Link to comment Share on other sites More sharing options...
drewbrese Posted August 26, 2022 Author Share Posted August 26, 2022 10 hours ago, rnr said: I wonder if it would be possible to register this car in CA. Do you have any pictures of the original build? Or history of how it was registered from 1978 onwards California DMV will ask for proof of it being assembled as a kit car. I do not have photos from what it looked like back in 1978 or prior to my ownership. It was, and currently is, titled and registered in Massachusetts as a 1978 Caterham Super 7. Link to comment Share on other sites More sharing options...
drewbrese Posted August 26, 2022 Author Share Posted August 26, 2022 10 hours ago, Cueball1 said: Was the built turbo motor installed day one or is it lower miles than the chassis? I do not know what engine was originally installed. I also think it's safe to assume that the miles on the current engine are much less than the miles shown on the odometer. Link to comment Share on other sites More sharing options...
