1 hour ago, wemtd said:
Update…
I ordered a 4post triumph lift: Sized for a se7en & most likely to fit my space.
Then garage modifications ensued for vertical clearance. Naturally this became exponentially more complicated than anticipated.
Now that that’s sorted I can’t even remember what repairs & adjustments the Se7en needed…
Have a pic of the lift?
Model number?
Who did you buy it from?
Edited by IamScotticus
Here is an interesting solution, especially for those with small garages. I just spoke with the owner of SuperLifts in Canada. Their lift is designed for ATVs, side by sides etc however those are very similar in size (and sometimes even heavier) than a 7. They are targeting the 2000 Max model for spring 2023. There is also a wall model.
https://superlifts.net/2000-max/
