pethier Posted July 31, 2024 Posted July 31, 2024 On 10/13/2022 at 2:50 PM, TheDingo8MyBaby said: I find the local O'Reilly's carries 20w-50 VR1, but it may be stored behind the counter (I checked first on their website where it was in-stock). It's not that much more than expensive than diesel oil. In West Saint Paul O'Reilly's, it is $7.60/qt when bought in 5-quart containers.
Grady Posted August 1, 2024 Posted August 1, 2024 I have studied this topic extensively and have come to the conclusion that New oil is the best. 2
Dave W Posted August 1, 2024 Posted August 1, 2024 The diesel oils have the ZDDP for the anti-wear but lack the anti-foam additives needed for the high RPM gasoline engines. I use 3qts of Mobile 1, 5w-30 and 1qt of VR-1 20w-50. I change oil once a season or if I reach 3000 miles along with a new Wix filter.
slowdude Posted August 2, 2024 Posted August 2, 2024 Since you can't get zinc easily, zinc addative or liquimoly friction inhibitor essentially serves the same function. 5W-50 for my k series.
