Rub the rough side across a flat file, sand paper, or nail board and you can reuse them. A thin washer under the head and/or dab of grease to the surface and the screw shoulder will be less likely to tear into them. Typically, there is only a ring gasket between the sender and tank with no sealing washers on the screws on top of the sender.
