1995 Westfield SE - Engine Professionally built by Burton - stack of service records and original build invoices
Hello,
I am brand new to the forum and pleased to offer for sale our 1995 Westfield SE that I imported from the UK. This Westfield engine was professionally built by the world renowned Burton in the UK and I have a stack of service records as well as all of the original build invoices from Westfield. This Westfield has only covered 10,858 miles from new. The vehicle comes with an original Westfield Tonneau cover. Since importing it we have installed a new starter solenoid and on/off switch. This Westfield has approxiamtely 140 horsepower and I have three different dyno run sheets for it. The vehicle is located at my dealership Peregrine Motors LLC in Huntland, TN and comes with a clean Tennessee title. I am more than happy tp help arrange shipping, we ship vehicles all of the time all over the USA.
Here is a video of the Westfield starting up, full walk around and short test drive:
Here are some of the specs for the vehicle that I got from the previous owner:
Engine Spec:
- bored to 83.5mm (1691cc)
- 1300 cc pistons pocketed to allow for extra valve lift
- Compression approx. 10:4:1
- Pistons, rod, crank and flywheel assembly fully balanced
-Flywheel lightened from 28 lb. to 12 lb.
- Kent 234 Cam
- Vandervell Shells
- Twin 40 Webbers
- line honed main bearings
- Heavy duty big end bolts
- New cam bearings
- Vulcan Maxiflow 1 head ( gas flowed, larger inlet valves and double springs) Not lead free
- Duplex vernier timing chain set
- Steel rocker posts
- High Pressure oil pump
- Bosch distributor - recalibrated to suit engine spec
- Standard clutch assembly
Diff:
- Standard MK2 Escort modified and reconditioned by Westfield, Ratio 3.11:1, with wheels and tires fitted this gives an overall gear ratio of 18.5mph/ 1000 rpm
Propshaft: Westfield
Gearbox:
- Cortina 2L 4 speed supplied by Westfield
Radiator:
- 4 core supplied by Westfield
Exhaust:
Stainless supplied by Westfield
I have the following original invoices from Westfield:
- build instructions
- foam strip
- safety harness
- front roll bar
- windshield washer switch and windshield wiper switch
- expansion tank, expansion tank hose and fan sensor switch
- original rolling chassis invoice
- tonneau cover
I also have pictures from the original owner from when it was being built.
Price is $25,000
Feel free to call me at 931-202-3020 or email me at: sales@peregrinemotorsllc.com
There are plenty of auctions that start at the sellers lowest sell price, that doesn't mean that's all they will get-the market will decide, all it takes is a bidding war and all bets are off..
Edited by spitfun
Yes you are right, I have also seen at car auctions in person when an owner thinks his vehicle is worth 75 K$ and at no reserve it sells for 15K$, and you still have you pay the auction house their 8%  Barrett Jackson was like that for a long time, I don't watch them or go to them any more
I put 2 cars on E bay, both buyers chickened out after the sale.   I would rather separate fly shit from pepper with boxing gloves in dim light than do it again
  • Haha 1
Hi folks, this is an interesting conversation about auctions and worthy of a dedicated thread if there is interest, but this is a for sale ad, and we are well off topic.  Out of respect for @peregrinemotors, let's please keep all further posts in this thread on topic.
Thanks,
John
