I'm trying to locate a 1" spacer for my steering wheel, but the only ones I can find in the US are drilled for a 1.75" PCD whereas the Momo uses a 2" (50.8mm) PCD.  That larger size is readily available from multiple sources in the UK, but before I commit to international shipping, I want to rule out a US source.  Any leads?
Thanks,
John
I'm thinking that pcd is a relatively new development by momo. Is it six screws? I think the older ones have a larger pcd. Not hard to find spacers for those here that are drilled to accept a variety of six screw wheels with 2.75-2.85" pcd.
One inch is pretty small. I assume that you're aware that the upper column can slide out to extend somewhat? I sit with my seat in the far back position and I haven't needed a spacer with my current setup.
You could make your own for about $20. Buy one inch of 2.5 inch rod from mcmaster but I don't know the method they use to cut it, so truing on a small lathe may be required on one face or just have a machine shop make the spacer.
Thanks, I made the one in the Westfield and it turned out well, but I would prefer the part to be powder coated or anodized rather than painted and doing so for a single part is expensive.  If I can't find a US source for the 2" PCD spacers, then I'll just buy it from the UK and bundle it with some other items that are difficult to source here or significantly cheaper over there.
