Further info.
Car went out for a bit, was getting lean spikes when i accelerated.
Went through and tweaked:
Accel enrichment:
  • Accel Max enrichment upped to 35%
  • Clamp 50
  • Decay 22
  • Accel Rate Threshold
Then, I was also getting some timing advances randomly when I would clutch in and coast -> Idle ignition control was set to 2100 RPM. Backed this down to 1350RPM, slightly above idle.
Next break in the weather and I will go out and test the changes. I didn't push too far given the lean spikes.
