WTS: TWM Individual Throttle Bodies for Ford 2.0 Zetec Engine (w/ Injectors)
linenoise
TWM was bought by Borla and these are currently for sale on Borla's site for $1875 *without* injectors (https://www.borlainduction.com/2000-series.html#200034)
Asking $1200 1100 1000 $950 900  $850 $800 shipped to any lower-48 US address
Includes injectors
Edited by linenoise
price reduction
Is there an air filter mounting plate included too that's in the first shot? How about the air filter itself?
The throttle cable is coming in from the front of the engine in your orientation setup right? Dimentions of the velocity stacks?
Air filter and mounting plate are not included.   These can be sourced from ITG.
I believe the throttle comes in from the front, but I'm nowhere near the car and cannot check.   The velocity stacks are 5cm high, 6cm inner diameter at top of the stack, 8.25cm or so outer diameter.
40 minutes ago, linenoise said:
looks like I have a mixed set.  3 red top injectors without discernable markings, 1 red top that appears to be this one:
https://www.injectorplanet.com/products/bosch-0280150945-ford-f1se-e5a
I hope they are all matching? That red top Bosch is a 30lb per hour injector which is fine and is matching what @catsv7 has on his car.
I'm prodding questions because I'm troubleshooting my car and might have to "bosch-0280150945-ford-f1se-e5a" in the end and if I do it makes more and more sense for me to potentially buy your ITB set as a backup and injector package than just getting injectors on my own.
I'll assume the others are the same but if you could confirm that they are it could be beneficial.
Thank you
The other 3 don't have any obvious markings -- I assume the are the same specs as the bosch as they came from the same car.   The other 3 are identical to each other.
11 hours ago, linenoise said:
I'll leave that up to the buyer.   I'm just tossing in the injectors for free, they aren't the core item for sale
To me personally they would be the core item of the whole deal.
Can you take detailed pictures of them and whatever engraving at all they might have?
Or if they aren't part of the whole deal technically are you willing to sell them separate?
Also how many miles are on the ITBs and their age?
Mine had to be rebuild by Borla/TWM and it cost me nearly the cost of the brand new unit to get them rebuilt even though they had ~2000 miles on them but TMU. I was expecting their basic rebuilt quote of just a few hundred dollars when I send them in as they list on the website..
Edited by Vovchandr
Detailed pictures attached.   After further inspection the 3 identical injectors have markings, which I believe to be BIN-945 and 3219.
I'd prefer to sell as a package but feel free to DM me an offer.
The odometer on the car is a little north of 9000 miles.   The car it came on was built around 2003 but I don't know if the engine is original or not.
