Vovchandr Posted July 25, 2023 Posted July 25, 2023 I think I have one lined up but just in case seeing if anybody has one kicking around that they've moved on from. Thanks
linenoise Posted July 26, 2023 Posted July 26, 2023 Ugh, I had one but I'm fairly sure I tossed it. I do have the programming cable if you are in need of one
Vovchandr Posted July 26, 2023 Author Posted July 26, 2023 6 hours ago, linenoise said: Ugh, I had one but I'm fairly sure I tossed it. I do have the programming cable if you are in need of one I hope it wasn't on the last week or two! I do have the cable too, I was actually recently able to use it without the USB adapter, pluging it in directly.
dallasdude Posted August 3, 2023 Posted August 3, 2023 I gave my last ones to Quicksilver. T2's is still the spec computer for FF2000 engines. Might want to check with them. We converted everything over to Haltech a long time ago. 1
CarlB Posted August 3, 2023 Posted August 3, 2023 Are you sure the ECU is damaged? It might be worth a try if you get your wiring and sensors figured out.
addict Posted May 12, 2024 Posted May 12, 2024 On 7/26/2023 at 6:47 AM, linenoise said: Ugh, I had one but I'm fairly sure I tossed it. I do have the programming cable if you are in need of one if you still have this programming cable, I'm chasing my tail on an issue with a Pectel T2 right now and desperate to rule out my cable as an issue -- would love to buy yours!
linenoise Posted May 13, 2024 Posted May 13, 2024 I gave it away a couple weeks ago to @Slonie, sorry.
addict Posted May 15, 2024 Posted May 15, 2024 No worries, I was able to build a new one that works -- for anyone looking for the cable in the future the attached wiring diagram is correct but I had issues with two cheap USB to Serial adapters. Also Windows 10 64bit is fine, you don't need to find a windows XP computer -- I took a last generation Intel based MacBook and installed Windows 10 via bootcamp and it's working perfectly. These are answers I struggled to find with google, hopefully the next person who stumbles onto this will have a slightly easier time. F2000_ECU_Flash_and_Verify_v2_.pdf 2
