Still in need of Handbrake lever for my 79. Any info about what they came off of / mods / and a source is greatly appreciated!
I don't know if you missed this conversation:
I also am in need of a handbrake lever assembly and have seen all the suggestions as alternatives, but none quite come up to the level of originality that I’m hoping for.  However, Mike Brotherwood in the UK apparently has a sporadic and dwindling source of levers that he modifies to be a close replica of the original.  They are understandably quite expensive, but as I said to him, “what other choice do I have?”  If this is anything like Mikes usual quality/standard I’m sure I will be very happy!
I believe he is working on a small ‘batch’ currently, so you might reach out to him.
Good Luck,
Ian
It could be cost effective to repurpose components and make a new body if needed. From scratch is a bit more involved with the gear cutting but still doable for a working if not authentic handbrake.
Mike’s price is not unreasonable at £390 especially considering the work that it takes.
I do think some low volume stamping tools could be made, the ‘gears’ could cut by laser or EDM so that wouldn’t be too bad, but with the number of likely sales, ROI is unlikely.
Id be happy to assist if anyone really want to take this on.
Ian
I am thinking they modified someone elses or made their own. The problem I am finding is with the original type, the sheath moved and the cable is fixed. So when you pull the lever, it pushes the sheathing. I have considered fabbing a bracket to adapt to the stock frame mounts and using the brake levers (I have all three other types posted in this blog), but it would just lower the handle in the footwell, which is in stock form intrusive. I am going to borrow the one from my buds 64 Seven and make one this winter. Will post how it turns out. Will have to make the fitting that pushes on the sheath too, brass should do there...
This lever came with my 7 project; it’s not Lotus 7, probably not MG TD of which there were many parts, but if someone would like to use it as a starting point for modification, I’ll be happy to send it for the cost of postage only.  It even has a bend in it . . Although probably in the wrong direction!
Ian
If the cable end clip on the chassis is not used, a typical hand brake  could be used with an adapter to attach to the two existing fastener positions. The cable could be rerouted if needed to change which way the handle swings.
Idea #1: small cable pulley (to reverse and pull action), mounted to a fabbed bracket with the cable sheath stop further under the tunnel.
Idea #2: Fabbed bracket with a cable sheath stop and a tab welded on the handle side of the lever to attach the cable to.
It would be cleaner and more compact just to use as-is without pulleys. A typical handbrake doesn't need tabs welded on. If you are referring to Ian's handbrake, it is mirrored and could be reassembled with the handle at the top (pivot pin ground out and welded to the other side), cable housing/sheath arm on the bottom, gear flipped on the base, gear stop pin pressed to protrude on the other side, pawl mounted on the opposite side of the arm with the pushrod in the handle rotated 180deg, adapter plate to pickup the four handbrake fasteners and two chassis fasteners, with the fork/tab for the cable end as part of that plate. The plate can have "guide rails" that hug the chassis tube to provide more support than just the two fasteners on the chassis. The handbrake would be offset an inch or so toward the driver to clear the handle and eliminate the need for a bend unless it is the tunnel that is in the way. The whole assembly can be offset left or right as needed if the owner doesn't mind having to drill a hole or two in the tube.
Edited by MV8
On 10/18/2023 at 9:05 AM, Vinman1 said:
Better photo of Handbrake lever
That looks like the lever in my 1995 Caterham. Can't tell from that picture if the lever arm is curved; mine is, and I would expect them all to be curved to provide more room for legs, knees, shins, etcetera.
Per Tony Weales book, They would bend them for those clearance issues. Not sure why the photo from Caterham has them still straight...
  • 4 weeks later...
At a certain camera angle the bend may be imperceptible.
It looks like that angle.
In this case, that brake looks like it would be a RHD.
Edited by IamScotticus
  • 3 weeks later...
My Handbrake lever from Mike BROTHERWOOD arrived recently, but unfortunately suffered some abuse in transit from the UK.  The plastic handle, some 70 years old and a bit brittle, broke into 3 pieces.  I’m sure it was just flung around as the package was quite small and light.
I ordered some black CA adhesive (superglue) and bonded the parts back together, while trying, not entirely successfully, to not glue my fingers together!
The result is not perfect, but by the time I’ve dressed it up a bit, it will be.  The lever fits the chassis, and and will give an authentic, if not original, appearance.
IMG_0054.thumb.jpg.7a90a67cf9ceea4100e394e4cf4d122e.jpgIMG_0055.thumb.jpg.075249522ec68d0dade3b2c05206629f.jpg
Slow progress, but progress it is!
Ian
Edited by ianashdown
