Timothy Keith-Lucas Posted January 17 Posted January 17 I've got some wonderful news. Carrabelle is a small port on the Gulf of Mexico, so we have a fiberglass repair shop that generally repairs boats that have lost in fights with solid objects. I took my "beyond repair" fenders and snout to them and asked them if they could prep for painting. "We can do that" was the answer. Two days later they showed me the flared front fenders - smooth as glass. Gorgeous. Reinforced as needed on the back side. I'll see the rest and post some pictures soon. I'll also tell you what it cost. As near as I can tell, having searched diligently, there is no source for old Sevens fenders and snouts in the US. Redline is gearing up to produce more, but a set for my S2 would push $2K with shipping. I'm really happy to have found an alternative. 5
Timothy Keith-Lucas Posted January 18 Posted January 18 It was a bit more than I expected - $1089 for the set, but that's half the cost of new ones, they did extensive repairs underneath, and they - of course - have all the holes drilled and in the right places. Smooth as glass, and a four day turn around.
IamScotticus Posted January 21 Posted January 21 Here is a USA source for these parts. I got a response from Motorsport composites in Wisconsin that they do have moulds for all wings and nose and are willing to manufacture. I have their permission to mention them on the forum. They don't have a website but do have a FB page. They can do color gelcoat by request at additional cost, but the default colors are black and white. I will add that these guys have been in the business a long time, at least 20 years, so there is no question they know what they're doing. Here is the email copy sans prices, as I believe pricing should be a private negotiation between parties. We have three different versions of a Lotus nose -- The 7 Series LS-II, DSK7 and the Caterham CS3. We have two versions of the front fenders -- The LS-II and 7/CS3. They are quite similar to each other, with only subtle differences. For rear fenders, we have either 9.5" wide or 11" wide. The 9.5" are universal. We have two different 11", which are very similar to each other. One is designated as CS3, the other as 7/DSK. I am told that the CS3 parts were for a special version developed by Carroll Shelby. If you would like to see the slight differences between the different fenders, let me know and I will dig out some pics. Noses are $XXX in fiberglass, $XXX in kevlar. Front or rear fenders are $XXX each in fiberglass, $XXX in kevlar. Carbon parts are also available upon request. Thanks, Wava Utt Motorsport Composites 2133 County Road W Grafton, WI 53024 262-375-1930 info@motorsportcomposites.com 1
Timothy Keith-Lucas Posted January 22 Posted January 22 Here's the "cap" for the Lotus nose badge: https://www.ebay.com/itm/323985454655?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D279229%26meid%3Db7ab0c58a4b549dc8f47880db0facb14%26pid%3D101506%26rk%3D2%26rkt%3D10%26sd%3D324206691484%26itm%3D323985454655%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecall%26brand%3DUnbranded&_trksid=p4481478.c101506.m1851
Bill Posted February 23 Author Posted February 23 Bad news: Just learned from Chris at Red Line that he is unable to furnish the nose S-2 nose cone that I ordered last April... so I am still looking for a nose cone. He said that the the Lotus S2 and S3 nose cones are the same except for the location of the Lotus emblem. The Caterham S3 nose cone is completely different. Lotusfan do you still have that nose cone....if not, any other leads? 1
Bill Posted February 23 Author Posted February 23 Thanks Scott! I will contact Motorsports composites. And thanks to all of you that contributed to this thread! 1
Bill Posted April 1 Author Posted April 1 Motorsports Composites nosecone: Thankyou Scott! I ordered a nose cone it from MSC. It fits quite well and the quality is good. I will need to make the following modifications: 1) cutout for the anti-sway bar 2) extend the skirt to fit the lower Dzus fasteners
Bill Posted April 1 Author Posted April 1 Incidently, about a week after I ordered the nose cone from MSC, I received a message from Chris at Redline that he had a S-2 nosecone that he could send to me! So if anyone is in the market for a nose cone, check with Chris and perhaps his product would need no modifications.
IamScotticus Posted April 1 Posted April 1 10 minutes ago, Bill said: Motorsports Composites nosecone: Thankyou Scott! I ordered a nose cone it from MSC. It fits quite well and the quality is good. I will need to make the following modifications: 1) cutout for the anti-sway bar 2) extend the skirt to fit the lower Dzus fasteners Do the headlamp brackets align under the openings?
IamScotticus Posted April 2 Posted April 2 2 hours ago, Bill said: Yes, the headlight brackets align under the openings Then that bottom edge should have reached the frame. They cut it short. I would ask for another, with corrections. Or take the opportunity to fab a hinge Piano hinge
IamScotticus Posted April 5 Posted April 5 I will try to be more helpful I measured the nose lower skirt on an original Lotus S2/3 and from a reproduction made by DSK, from the period. They were both very close. LOTUS DSK
MV8 Posted April 5 Posted April 5 I'd epoxy two, .050" low carbon steel sheets inside the nose then add the dzus to that, so no chassis mod or holes in the nose for rivets. Each sheet would lap the nose about three times the area of the chassis tab. Not that it would be necessary, but you can add 3/8-7/16" to the left and right side of the patches to bend up for more rigidity. If the patches need to be curved to fit, just bend to 45 deg.
