Help! Installing new Caterham LED Taillights
has anyone installed the new Caterham LED taillights and got them working properly?
my car is a 2005 Zetec if that makes a difference.
I followed the video instructions (it’s pretty straight forward) from the Caterhamparts.co.uk site but I’m having all sorts of issues such as:
1. the left and right turn signals flash at double speed - which is the sign of something wrong
2. The lights are dimmer when my headlights are in and brighter when DRLs are on
3. The hazards flash at normal speed
4. Sometimes the lights are brighter and sometimes they are dimmer
my car does not have the standalone reg fog light at the back like UK cars do so I haven’t plugged anything into that pigtail. Could this be the issue?
I have tried putting the wiring loom in both ‘ directions ‘  i.e. left side of the loom on the left side of the car , and left side of the loom on the right side of the car
a few vids :
https://share.icloud.com/photos/0200nRzHUiiGKlyx6w_QAdpUw
https://share.icloud.com/photos/0ea0yXh2q-23_b7pvliJMzEbA
https://share.icloud.com/photos/039MLwf1QVx1X158hjbXeXXZw
https://share.icloud.com/photos/0caIvXkYtOna-mRm1gNGdYuDA
Edited by das76
  • das76 changed the title to Help! Installing new Caterham LED Taillights
I’m not familiar with the caterham wiring schematic.
however the Birkin wiring uses the resistance of incandescent bulbs as ground for indicator lights [this is my non-engineering understanding]
When I installed LED lights for rear indicators everything went wacky….
this was resolved by inserting an diode assembly between switch/lights/ground
the flasher depends on the incandescent bulb load to operate properly  LEDs are lower load, so it thinks you have a bulb out, and flashers faster
hazards are seeing enough load from 4 LEDs
easy fix is to get a flasher for LEDs from feebay or such
or you can parallel resistors to the Leds to increase load
Edited by 7Westfield
Thanks. I also posted on a Facebook group and several people said to replace the flasher relay.
It’s very frustrating that Caterham a) don’t include it or b) don’t mention that you should order it separately
anyways… I’ve ordered one online and it should arrive Tuesday and I’ll provide an update.
Edited by das76
I installed the flasher unit shown above. All is right in the world!! Case closed. Thanks all!
For backup you can get these at advance auto. Same as land rover ones for some reason.
