pethier Posted August 3, 2024 Posted August 3, 2024 (edited) My 1700 Super Sprint came to me with NGK B8EC S spark plugs. It seems to run well. Should I stay with these, or is there a reason I should use different plugs? Torque is probably not critical in an iron head, but what should I shoot for? What spark-plug gap should I use? The car is used for autocross and pleasure drives. Long trips to distant places is done in a trailer. Edited August 3, 2024 by pethier
7Westfield Posted August 7, 2024 Posted August 7, 2024 (edited) I run NGK BCP6ES in both 1600's In my Westfield and a formula ford they come gapped about .030 and that seems fine 20-25 lbs torque I forget how NGK runs their temp scale if the B8 is colder, and you have higher than stock compression, I'd think it was OK too Edited August 7, 2024 by 7Westfield
pethier Posted August 7, 2024 Author Posted August 7, 2024 2 hours ago, 7Westfield said: I run NGK BCP6ES in both 1600's In my Westfield and a formula ford they come gapped about .030 and that seems fine 20-25 lbs torque I forget how NGK runs their temp scale if the B8 is colder, and you have higher than stock compression, I'd think it was OK too A search locally turns up BCPR6ES. which MAY be the same thing in a "resister" plug. Is this OK?
7Westfield Posted August 7, 2024 Posted August 7, 2024 (edited) I think you are right on the "R", but since you have no radio... https://www.ebay.com/itm/166754639181?itmmeta=01J4Q1JP7DMNVRH97TB1D84C4Z&hash=item26d359dd4d:g:8QMAAOSwN3FmPYJo&itmprp=enc%3AAQAJAAAAwHEFCD%2BbD8X3zxALyvEqwkP0%2FD9rOUTBupB0xxemnFIBCQrJUtovhVjq4au9oyJ8oz4pV0iOmWL4%2BvGzn9%2BZtwypGJU3wIHSjknnPtcT1qGYXQID7EGm%2B18T2QG%2Br5LS%2BwCdXXobWM4C3TzpaLnvFF%2BjgKfBr5f2vU%2FccHRLGjoe%2BunYGKRVcYOhyznA4nJMklcJEphxsP42X8rE5y5gxh8UJcAXfg6Cke4CVSHUKoFz0Q1LK161p0Bw1h%2F9jtu8kA%3D%3D|tkp%3ABk9SR-bjyuGlZA or search for them by the stock # 4930 Edited August 7, 2024 by 7Westfield
pethier Posted August 7, 2024 Author Posted August 7, 2024 Shipping is always the problem with me. I have tracked down some BCP6ES to be delivered to 2 local NAPA stores.
IamScotticus Posted August 8, 2024 Posted August 8, 2024 Whatever a 1971> 1600 OHV Escort would use. Uprated 711 or AX crossflow
