ianrobb Posted September 13 Share Posted September 13 I've wanted to build a Lotus 7 type car for several decades now. I'm pushing 40, and no better time than now to start. I started with a McSorley 442E, Figuring that the bigger it is, the more likely that my "larger" friends could fit. After I built the basic frame, I started looking into the suspension design, which was giving me anxiety, since I wanted to use NA/NB Miata diff, axles, uprights, etc. I was told that the 442 was too wide to use stock axles. I didn't want to go down the rabbit hole of custom length axles, designing my own control arms, mounting points and geometry. I have a full time job, a 10 year old son, and a baby girl, I don't have time for all that. So, I cut it all up, and used the pieces to build a Haynes Roadster, using the Saturn Sports Car plans to adapt to MX5 running gear. This way, most of the work was done for me. Planning on using a Ford Duratec 2.3, NC Miata 5-speed, NB Miata rear diff, axles, uprights, brakes, steering column, and other small bits. Oh, and don't worry, the irony isn't lost on me, that the time spent cutting up one frame, and building another probably took longer than just sticking with the first frame. Anyway, I'm almost ready to start fabbing up some control arms. 2 Link to comment Share on other sites More sharing options...
JohnCh Posted September 13 Share Posted September 13 What are your plans for the engine? Are you keeping it stock or going with changes to the induction or internals? Do you know yet what you’ll use for the ECU? Link to comment Share on other sites More sharing options...
ianrobb Posted September 13 Author Share Posted September 13 34 minutes ago, JohnCh said: What are your plans for the engine? Are you keeping it stock or going with changes to the induction or internals? Do you know yet what you’ll use for the ECU? Stock internals, for now at least. It's rated at 160 crank HP stock, but I'm planning on using Cosworth style intake, freer flowing exhaust, plus without power steering and A/C, I'm expecting to be around 180 crank HP. Not planning on turbo or supercharger, I want to keep it light and simple. My ultimate goal is about 200WHP, all motor, probably with a 2.5L Duratec. Stock ECU, with immobilizer delete, possibly a mild tune. 1 Link to comment Share on other sites More sharing options...
IamScotticus Posted September 13 Share Posted September 13 (edited) I would like to know how Haynes goes from Ron Champion to Chris Gibbs, for the same car. I found out. The Champion build is escort based. The Gibbs is Sierra based. I do hope there is a nod to Ron in the later. Edited September 13 by IamScotticus Link to comment Share on other sites More sharing options...
ianrobb Posted September 13 Author Share Posted September 13 8 minutes ago, IamScotticus said: I would like to know how Haynes goes from Ron Champion to Chris Gibbs, for the same car. I found out. The Champion build is escort based. The Gibbs is Sierra based. I do hope there is a nod to Ron in the later. The Gibbs car is also referred to as a +221, 2" longer and wider, 1" taller, than the Ron Champion version. Link to comment Share on other sites More sharing options...
MV8 Posted September 13 Share Posted September 13 I found the Gibbs plans to be the same length as the 442 in overall chassis length. Have all the chassis dims compared in my sig on locostusa, which has once again crashed. Link to comment Share on other sites More sharing options...
ianrobb Posted September 13 Author Share Posted September 13 4 minutes ago, MV8 said: I found the Gibbs plans to be the same length as the 442 in overall chassis length. Have all the chassis dims compared in my sig on locostusa, which has once again crashed. Interesting. I've never compared the 2 dimensionally. I just know they Haynes is 2" narrower than the 442. The seatback is also lower on the 442. Link to comment Share on other sites More sharing options...
MV8 Posted September 13 Share Posted September 13 A few years ago,I thought it would be interesting to compared all the plans I could find for a few basic dims, but I don't think I ever posted it: 1 Link to comment Share on other sites More sharing options...
