Lotusfan Posted Thursday at 07:36 PM Posted Thursday at 07:36 PM Does anybody in the US have a suggestion on obtaining a new muffler for a Series 2 Seven, or have knowledge on how feasible it might be to cut one open to repack it? The problem is that the inlet accepts a 1 5/8” pipe and the muffler is 2 3/4” in diameter. Local exhaust shops aren’t interested when I tell them the tube diameters. I’m wondering about finding a motorcycle shop.I don’t know for sure if what I have is original but my suspicion that it’s about right for the period and I’d like to keep it similar.
MV8 Posted Thursday at 08:06 PM Posted Thursday at 08:06 PM It could cut at the end welds and along the seam lengthwise, then the cover spread just enough to slide over the end cap. Packing doesn't last that long and the muffler design is not very effective. It could be made rebuildable so that cutting and welding is not required. Could also be made a bit larger in od. Hidden inserts for the tip can be made or bought to quiet it down as well.
EdWills Posted Thursday at 09:49 PM Posted Thursday at 09:49 PM Hi. Would a farm tractor dealership be of use? Many of the farm tractor manufacturers such as Massey Ferguson, John Deere etc., produced silencers in imperial sizes that look like your unit, and they may have the right size for the Seven. Your unit certainly looks original. I found a company in the U.K. that produces an oval silencer identical to the unit used on the original Series 3 (not the later round one used on the Twin Cam and Caterham models with the leg protector fitted). They sell the stainless steel cover, imperial size tubes for welding to the cover, wire wool, internal baffle and fibreglass to pack inside the silencer, all as separate items. A round silencer similar to yours is also available. See: http://www.jetex.co.uk. I have used this company, and found them very helpful. Hope this helps. 1
Lotusfan Posted 22 hours ago Author Posted 22 hours ago Thanks for the replies and suggestions! I found a local exhaust shop willing to take a look, but they weren’t excited about the 1 1/2 inch tubes. The tractor suppliers look promising as a few minutes on the Tractor Supply site shows stuff that might work and look right. Thanks!
IamScotticus Posted 22 hours ago Posted 22 hours ago Looking myself for 1 3/4" glass pack type or baffled traight pipes
MV8 Posted 21 hours ago Posted 21 hours ago 53 minutes ago, IamScotticus said: Looking myself for 1 3/4" glass pack type or baffled traight pipes Body length and how big a diameter? 1.75 in and out? Slip fit ends or butt weld? Offsets for a bigger diameter for a more effective muffler?
Joe Petty Posted 21 hours ago Posted 21 hours ago I built my own exhaust: Maniflow 4-2-1 header, 1 3/4 flex, tractor muffler, various sleeves... I can't find the receipt, but the muffler is 1 3/4 in and 1 1/2 out, the can portion is 13" x 3" It is a standard tractor muffler that I bought online somewhere. These mufflers are straight through and kind of loud. I stuffed some expanded wire mesh inside to baffle to an acceptable level. The flex pipe has sleeves welded on to adapt to the different size pipe and is also welded to the muffler. The flex pipe and sleeves is 12" Maybe not the most elegant arrangement, but saves trying to get the pipes to fit and not leak! Not obvious in the picture, but there are 2 short brackets welded to the inside front and back of the muffler can that bolt to rubber mounts to the frame. Good Luck! - Joe 1
IamScotticus Posted 11 hours ago Posted 11 hours ago (edited) 9 hours ago, MV8 said: Body length and how big a diameter? 1.75 in and out? Slip fit ends or butt weld? Offsets for a bigger diameter for a more effective muffler? Nor sure. But staying with 1600 and 1.75. Not using the original muff. Looking for something that won't get caught and rip off my wing. Wing ripoff proof. Not wanting to hijack, hoping I can find what I'm looking for in the suggestions here. Edited 11 hours ago by IamScotticus
IamScotticus Posted 3 hours ago Posted 3 hours ago (edited) This is more what I'm looking for, it's a Harley Davidson cigar muffler. This is a reproduction from Lowbrow Customs. 1958-72 cigar muffler by Gasbox. OEM # 65235-58. Out of stock at this time. I haven’t looked everywhere. Edited 3 hours ago by IamScotticus
