3Ducs Posted April 13 Author Posted April 13 On 4/2/2026 at 1:57 PM, pethier said: It's raining pitchforks and hammerhandles just now. I'll atempt to get out there today. 2 hours ago, pethier said: The buyer of my 1700 did not put the engine in a Birkin. That engine/5-speed is bound for a Lotus 7. Whether the mounts I supplied with the engine/5-speed will fit the Lotus without a lot of work has yet to be known to me. I am absolutely certain they will not fit a Birkin. Birkin uses one horizontal bolt at the chassis, which seems a bit unusual to me. Thanks, I see that now. Chasing down the proper mounts has been like the quest for the holy grail. The originals from my Birkin were sent with the buyer of the Kent engine, even though that engine wasn't going into a Birkin. Tom Carlin doesn't have the drawings for the Kent motor mounts so he can't make them.
3Ducs Posted April 23 Author Posted April 23 On 4/12/2026 at 8:17 PM, 3Ducs said: Thanks, I see that now. Chasing down the proper mounts has been like the quest for the holy grail. The originals from my Birkin were sent with the buyer of the Kent engine, even though that engine wasn't going into a Birkin. Tom Carlin doesn't have the drawings for the Kent motor mounts so he can't make them. Nevertheless, those mounts might make the basis of mounts I could modify to work with my Birkin. Might they be for sale?
pethier Posted April 23 Posted April 23 15 hours ago, 3Ducs said: Nevertheless, those mounts might make the basis of mounts I could modify to work with my Birkin. Might they be for sale? For some reason, I have not been able to find them. I had no reason to pass them along, so they must be hiding somewhere in my attic, basement or shop. I will look again. 1
3Ducs Posted April 23 Author Posted April 23 3 hours ago, pethier said: For some reason, I have not been able to find them. I had no reason to pass them along, so they must be hiding somewhere in my attic, basement or shop. I will look again. 3 hours ago, pethier said: Thank-you! I wish Jimmy had retained the mounts when he sold the X-flow that was originally in the car! Who knew it would be so difficult to find motor mounts?
3Ducs Posted May 1 Author Posted May 1 On 8/2/2025 at 1:14 PM, pethier said: I have located what I assume are the original Caterham factory mounts for my 1700 Super Sprint (which I assume is the same as other Kent motors). They may or may not be the same as a Lotus mount. In any case, they have been sold with my 1700 Super Sprint engine el al, pending delivery. You will note that the engine interface is quite unlike the Zetec I can see that these will not work for my car, thank-you for the photos.
3Ducs Posted May 1 Author Posted May 1 On 3/28/2026 at 9:12 AM, 3Ducs said: Any chance these are for sale? I'm having no luck finding mounts to fit the Kent engine I'm getting, these look close to what I need. Have you located these mounts? They are more like what I think might work or be more easily modified to fit my application. I am more than willing to make it worth your while to find them.
3Ducs Posted May 6 Author Posted May 6 On 8/2/2025 at 2:19 AM, pethier said: Yup. Looks Birkin. Found my Birkin/Zetec mounts today. Forgot to shoot them. Sorry to take so long to get back to you about your engine mounts, do you still have them? I'd like to buy them, they might not fit exactly as found but could well serve once modified.
pethier Posted May 7 Posted May 7 On 5/1/2026 at 10:30 AM, 3Ducs said: Have you located these mounts? They are more like what I think might work or be more easily modified to fit my application. I am more than willing to make it worth your while to find them. Still looking around. I have apparently stored them so well I can't find them. 1
3Ducs Posted May 22 Author Posted May 22 On 5/6/2026 at 9:45 PM, pethier said: Still looking around. I have apparently stored them so well I can't find them. Yesterday a friend said that a friend of his is a metal fabricator, has a CNC machine etc, and can probably come over and make mounts when my engine arrives. I have a new set of Birkin mounts to fit a Zetec engine so I have a start at the frame side. I'll level the car up on jack stands, mount the exhaust manifold and level the engine, that should give us a start.
pethier Posted May 23 Posted May 23 4 hours ago, 3Ducs said: Yesterday a friend said that a friend of his is a metal fabricator, has a CNC machine etc, and can probably come over and make mounts when my engine arrives. I have a new set of Birkin mounts to fit a Zetec engine so I have a start at the frame side. I'll level the car up on jack stands, mount the exhaust manifold and level the engine, that should give us a start. Sounds good. A fabricator who will work with 3D objects like this is a rare find. 1
