KnifeySpoony Posted October 26, 2025 Posted October 26, 2025 Need to replace my fuel pump in my 2021 420R. I know it's a Ford pump but does anyone know if it's an off-the-shelf Ford part or is it specific spec for the 7? This is the unit that CC sells: https://caterhamparts.co.uk/pumps-senders/5501-fuel-pump.html It's out of stock and probably more expensive that buying it locally from my Ford parts counter, if it's available.
Croc Posted October 26, 2025 Posted October 26, 2025 The top of the pump should have a sticker with bar codes plus there should also be an embossed plastic product code on the unit. Get photos or tell me what they are and I think I will be able to find a substitute product stateside in 10 mins. There is this thing on the internet called Google.... 1
MV8 Posted October 26, 2025 Posted October 26, 2025 2000-2002 Ford Focus. The complete assemblies are $50-100 and the pumps by themselves are $10-100. Carter and delphi are good brands. https://www.rockauto.com/en/catalog/ford,2001,focus,2.0l+l4+dohc,1385524,fuel+&+air,fuel+pump,6256
Croc Posted October 26, 2025 Posted October 26, 2025 8 minutes ago, MV8 said: 2000-2002 Ford Focus. The complete assemblies are $50-100 and the pumps by themselves are $10-100. Carter and delphi are good brands. https://www.rockauto.com/en/catalog/ford,2001,focus,2.0l+l4+dohc,1385524,fuel+&+air,fuel+pump,6256 There is also an earlier Focus version used as I remember swapping in one in my 2018 420R - just check the product number to confirm. Only thing that did not come with it was the wire float but you just swap that over. Huge saving over the 320GBP that Caterham is charging. Love Rock Auto! 1
MV8 Posted October 26, 2025 Posted October 26, 2025 Rock just shows domestics. The focus was not offered here until 2000 but I expect the pump is the same as a euro 1998 focus. For those looking for a return line pump assy that SHOULD fit the cat tank opening and depth, look at the Ford Escape/Mazda Tribute pump assy.
speedwagon Posted October 26, 2025 Posted October 26, 2025 Not having a lot of luck with my obs ford pickup fuel pumps, I was taken back when seeing "famous brand" designed by Carter (likely copied/ hi-graded) . In my shop Carter is a dirty word. But do have an escape/tribute setting outside dead that recently ran with one dead cyl. might actually be a usa pump pr perhaps jdm.
MV8 Posted October 26, 2025 Posted October 26, 2025 I think the escape/tribute pump assy will stick up higher by a half inch or so than the focus pump due to the fittings. I've not used any carter other than the gerotor pumps made for carbs. Those have been excellent.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 (edited) 8 hours ago, Croc said: The top of the pump should have a sticker with bar codes plus there should also be an embossed plastic product code on the unit. Get photos or tell me what they are and I think I will be able to find a substitute product stateside in 10 mins. There is this thing on the internet called Google.... Obviously I have searched for this information. The part number is on the top of my pump (bv61-9h307-dd). I didn't know if the internals specs or dimensions of the unit/float is different as used by Caterham. Hence my question... 8 hours ago, MV8 said: 2000-2002 Ford Focus. The complete assemblies are $50-100 and the pumps by themselves are $10-100. Carter and delphi are good brands. https://www.rockauto.com/en/catalog/ford,2001,focus,2.0l+l4+dohc,1385524,fuel+&+air,fuel+pump,6256 So.... can we confirm that the part is indeed an off-the-shelf Ford part without any modifications? Or are we just assuming? Edited October 26, 2025 by KnifeySpoony
MV8 Posted October 26, 2025 Posted October 26, 2025 (edited) It isn't obvious that you've determined anything. The number crosses to a standard 2013-2017 focus ST for the euro market (about $100). Could Cat be shipping these to someone who mods the board to work with the Cat speedo? Why ask? You are in a better position than anybody to determine that because you have their pump in-hand. Spend a few bucks to get a focus assy (1gen or euro 3gen), remove yours, compare the resistance change when swinging the float arm to compare. If the swing is different, swap the resistor board to the pump you bought. EDIT: I found the ohms for the 1gen: 15-160, 3gen 464-50, Empty-full. Since you are not going to run a return, the 3rd gen euro is the best bet for matching pump output. For those who have not researched, here is a list of equivalent pumps to the part number on the Cat supplied pump: BV61-9H307-DA BV61-9H307-DB BV61-9H307-DC BV61-9H307-DD Fuel Pump Module Assembly Unit Compatible With Ford Focus III 2013-2017 2.0 ST Compatible With FORD: 1779841 Compatible With FORD: 1788061 Compatible With FORD: 1839104 Compatible With FORD: 1851813 Compatible With FORD: BV61-9H307-DA Compatible With FORD: BV61-9H307-DB Compatible With FORD: BV61-9H307-DC Compatible With FORD: BV61-9H307-DD Compatible With BOSCH: 0580200182 Compatible With BOSCH: 0580200183 Compatible With ERA: 775697 Compatible With FISPA: 72582 Compatible With HOFFER: 7507663 Compatible With HOFFER: 7507663 Compatible With INTERMOTOR: 39559 Compatible With MEAT & DORIA 77663 Compatible With SIDAT 72582 Compatible With WE PARTS 320900894 Compatible With FORD Imported Compatible With FOCUS III 20 ST 2012-2017 R9DA,R9DB,R9DC,R9DD 1999 184 Hatchback Compatible With Ford (imported) Compatible With FOCUS III Turnier 2.0 ST 2012- R9DA,R9DB,R9DC,R9DD 1999 184 Edited October 26, 2025 by MV8
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 For some reason on rockauto, it does not show the pump part number I have. Looking at other sources, it shows my part number as being for a 2012 Focus. But then looking up 2012 focus on rockauto, it shows different part numbers, not the one I have.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 This is the only thing on rockauto that comes up for BV619... https://www.rockauto.com/en/moreinfo.php?pk=14260833&cc=0&pt=10147&jsn=10916 Not sure if the image is supposed to be representative, but the top of the housing and layout of connections looks different. For instance for a 2012+ focus, the Delphi FG1532 comes up, but the listed OEM compatibility does not match my pump: https://www.rockauto.com/en/moreinfo.php?pk=7333804&cc=1501060&pt=10147&jsn=10895
MV8 Posted October 26, 2025 Posted October 26, 2025 Domestics are listed on rockauto and the descriptions can have errors. Search on amazon.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 And obviously I have tried to find a source that lists a BV619H307DD compatible pump, but I cannot find a US source, and I am afraid of random ebay sellers selling unbranded stuff. If need be I will pay shipping/tariffs, as they're still much less than what Caterham is charging.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 Just now, MV8 said: Search on amazon. Amazon will not ship fuel pumps to CA for some reason. We have bizarre hazardous/banned materials laws here...
MV8 Posted October 26, 2025 Posted October 26, 2025 I will provide a link or two for the pump through amazon for domestic shipping.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 Amazon will not ship one to me. Looking at the design of the pump and "hanger" mechanism - it looks like the depth of the pump may be adjustable with the hanging rods. I assume if a pump I get is different depth than what I have, I can easily adjust it? Or is this depth fixed?
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 Best guess is BV619H307DD is a Euro-only part number. But cross-referencing to domestic part numbers seems impossible despite the last 2 hrs of my googling. I will either have to take a leap of faith and hope the domestic part works, or buy from Europe.
MV8 Posted October 26, 2025 Posted October 26, 2025 The bucket has compression springs on the rods. Installing the pump lid to the tank compresses the springs to load the bucket against the tank floor. Still looking for a domestic source.
KnifeySpoony Posted October 26, 2025 Author Posted October 26, 2025 Interesting when I pulled my pump for inspection it didn't appear it would hit bottom and I didn't feel any resistance when replacing it.
MV8 Posted October 26, 2025 Posted October 26, 2025 Couldn't find the gen3 euro pump domestically. What I found is probably what you found. There are a number of pumps for asian market ford 2.0ls with the same connections that are in CA and use a different suffix on the basic ford part number but I didn't research them further. Tariff pumps: https://www.ebay.com/itm/315124235161?_skw=bv61-9h307-&itmmeta=01K8GNJJVR53831TTVW0MADDFB&hash=item495ede3b99:g:i5sAAOSw56plthLf&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1c7xksH4LqOYh1JCMMQ6BP34CRWzhE2xcPCDBiAMBHGqMbl7hyuAyN7My%2F1eXyKJ1q9SA2kYNjF9w5erbqJpqhQEs%2FPtrsAs%2BgTkQBMn3LLTLPfpN2R2BTc3fPxpGYBV4aKPvCWkpYJNQWXq6HQ8Th9m4LRfuDG5wXL0IWNKqLHfGlrxNHW4gnhj%2FDp71UurjizzdriGP1PScCWV6b4eN4teftH3HS56KT12%2B%2FIa%2FZ%2Bt0ywyK6NvuHrOkW%2BQvCNRcTVTVEIs0I5X1o9vV8hQZWUm5WXzBg%2FZzvP1KOlql6FlA%3D%3D%7Ctkp%3ABk9SR46uypXEZg https://www.amazon.com/BV61-9H307-BV61-9H307-DB-BV61-9H307-DC-BV61-9H307-DD-Compatible/dp/B0FSZD7ZDK/ref=sr_1_1?crid=32PY7NKRTJ17I&dib=eyJ2IjoiMSJ9.cBOLXe_7Q4OzBl-UV_QctA.Rvd1PeVEbtN9qdYnJ_88icLYmwt-cFIuTn3g9_N356M&dib_tag=se&keywords=BV61-9H307-DC&qid=1761497510&s=automotive&sprefix=bv61-9h307-dc%2Cautomotive%2C103&sr=1-1-catcorr
