IamScotticus Posted January 7 Posted January 7 for miss-matching bits Spiyda Gauge Wizard https://spiyda.com/gauge-electronics/the-gauge-wizard.html
Slonie Posted January 8 Posted January 8 This is really interesting! I went down the rabbit hole on temp senders when I was redoing my cooling system, this may have been an interesting solution. It says it has five calibration points, could we even use it to make the OEM fuel gauge read a little more accurately?
IamScotticus Posted January 8 Author Posted January 8 (edited) I believe that is the intent. Signal is signal regardless of the application? Petrol guage is in the description. Funny, I discovered this menton on the L7C site from a poster who was giving everyone his plans for a breadboard DIY copy of the device because the Spiyda is too pricey. I was smart like that, once. Edited January 8 by IamScotticus 1
BruceBe Posted January 8 Posted January 8 For 2016+ Caterham fuel gauges, we have a tool-less, plug-in corrective module that provides a much more accurate reading. Most importantly, it reduces range anxiety due to the stock setup reporting prematurely low remaining fuel levels. Just plug it in between the gauge and the harness. Caterham Fuel Level Correction Module Cheers, -Bruce 1
toldfield Posted January 8 Posted January 8 Bruce, Will this work in an older '82 S-3 with Smith's gauges? Tom
BruceBe Posted January 9 Posted January 9 Tom - this current product is designed to work with the newer gauges and calibrated for the later fuel sender assemblies. We are considering a version of the product that will work with the older gauges and tank/senders. We have a car in the shop right now with the older setup, and will be gathering the necessary sender level data. Cheers, -Bruce 1
