Can Spark plugs make a noticeable difference....r400
Doing online searching I found numerous references to plug recommendations for the r400 Duratec...they mostly led back to NGK BR7EFS plugs...the regular copper off the shelf not special plugs.
The Caterham provided NGK TR6AP 13 is a more expensive laser platinum plug.
So, I tried the BR7's gapped at the recommended r400 mentioned .9mm.
Man, I've never really felt a difference in a plug before but this was really noticeable. Nice to have others experiences noted and saved on line.
That copper old school was much smoother at lower rpm (especially when fully warm) and great at wot.
I've tried both and not felt a difference in my car.  I know on blatchat some people really favor the BR7.
Edited by KnifeySpoony
I noted quite a difference.  Going thru the work done on the car the injectors were upgraded and a few other things.... prior guy tracked I suppose.  Not sure if that would make a dif but the TR6ap's were not consistent throughout the rpm range.  Especially when the lump was up to fully warm (never gets hot), sat for a bit, and was restarted.  Slight hesitation at low rpm's for just a short period of time, then fine, like clearing your throat....they only had 3k on them btw.  That issue is now gone.
Seems stronger thru the rpm scale but that is seat of the pants and could be me.
The other issue for me was our gas.... 91 is the highest locally available and I get that 95 RON is our 91.... but we have hot summers and a cooler plug couldn't hurt given the compression figures.  I use ACES 4 to raise the numbers and it is a good injector cleaner too.
The TR6 is a colder heat range with a wider gap. If the ignition coils are not up to firing under all conditions, a smaller gap will improve running. A hotter plug can help as long as the tips are not melting. In general, boosted typically take a colder plug and smaller gap to prevent plug failure/overheat.
Thanks... the gap on the TR6 is wide ..., so is the BR7 and I took my info from numerous 7 websites and a builder that recommended the set up I described above for the r400D... it is a wider gap than normal but appears to work very well.  Very smooth at idle and just right thru the rpm range.
They noted the TR6 having issues at wot.
I like a colder plug in Az due to the 91 octane and ambient temps.... I could try a BR6 in the winter (60's and 70's) and the 7's come summer... regardless it does run fine and better than it did with the TR6's for whatever reason..
BR7 come with a 0.9mm (about .035") gap. TR6-13 is a 1.3mm gap.
Mine came with a much tighter gap, I had to open them up to .9... I didn't measure what they were tho.
I would advise googling ‘fake NGK plugs’ apparently it’s fairly easy to check the quality with an ohm meter,and fake ones may disassemble themselves in the cylinder. Not yet a seven owner but I have one in my sights to accompany my Type 14 Elite.
The world we live in.... I didn't buy them on Amazon.  Do a search...those BP7's normally come with a .028 to .030/.07/ to .08mm gap...not a .9 mm.
Edited by Reiver
You're funny Reiver, and that is not a bad thing. We've got to stick together.
"Shucks Mister. It's gotta be true. I read it on the internet"
When given my choice of influencers online, I'll go by the manufacturers catalog.
Gaps are adjustable for most plugs and there are many reasons they can be off but the BR7EFS is intended to be .035" from NGK, according to NGK. I have no doubt that you needed to adjust the gap.:cheers2:
No big deal but I got them from O'Reilley's and the preset gap was advertised and was at .028.  Not debating just what it was.  Not meant to be a pita as you've been a great help.
NGK Copper Plug Number BR7EFS Spark Plug 1094 | O'Reilly Auto Parts
UPC:
87295110942
Seat:
Tapered
Thread Size:
M14-1.25
Heat Range:
7
Hex Size (mm):
16mm
Hex Size (in):
5/8 Inch
Preset Gap (in):
0.028 Inch
Preset Gap (mm):
0.7mm
Thread Reach (in):
0.689 Inch
Unit of Measure:
Each
Center Electrode Tip Material:
Nickel
Approximate Resistor Value (Ohm):
5000 Ohm
Insulator Height (mm):
52.5mm
Insulator Height (in):
2.070 Inch
Ground Electrode Tip Material:
Nickel
Thread Reach (mm):
17.5mm
Service Number:
BR7EFS
Metallurgy:
Copper
Center Electrode Core Material:
Copper
Edited by Reiver
