Looking for Series One Seven suspension components  - What do you have?
Left Upper rear trailing Arm
Left Lower rear trailing arm
Right Upper trailing arm
Right lower Triangle Support
Left Front Lower A Arm
948 Header
Radiator - Spriget  - Inlet /outlet on right side
Front Nose - used/beat/bent - but savable Al of Fiberglass
Thanks Chris D - 585 330 5456 -   cdmad4494@aol.com
If you have the required dimensions, or better, an example of what you need, there are several guys in open wheel racing could duplicate the parts for you. Try Momentum Motorsports at CMP in south carolina.
have you tried GMT Racing?   -for the suspension
gmtracing.com
I ? if you have a spridget rad, stock ones all seem to have in + out on opposite sides
maybe it's a racing unit....you might try Clancy Schmidt in Lawrence KS   he has made/sold racing spridget stuff for YEARS
Edited by 7Westfield
