solder_guy Posted October 15, 2006 Posted October 15, 2006 Got busy today .. removed the seat back and bottoms .. and swept and vacuumed all the debris which had built up for a long time. Also cleaned out the back storage area. Partially removed the carpet. Gotta cut out a pattern for replacement. Removed the two fender mounted mirrors. They were crap anyway. Makes the car look alot more lean. I need some new seatbelts right away. These are too old and dry rotted. Four point on the driver and three point on the passenger. The seat bottoms were damp from moisture exposure. They are currently drying in the sun .. upside down in the yard. All will be reupolstered .. over the winter. Rob Mitchell
Boxologist Posted October 16, 2006 Posted October 16, 2006 i have a 5 pt simpson(short strap) i don't use. i would just need to find it.
solder_guy Posted October 20, 2006 Author Posted October 20, 2006 i have a 5 pt simpson(short strap) i don't use. i would just need to find it. I spent some time tuning the two carbs yesterday. Then took two laps around the block! Whee! For some reason my car does not have a VIN plate. Dennis Hedges is going to stamp one and get it in the mail to me soon. 1981R070000000014 Rob Mitchell
solder_guy Posted October 24, 2006 Author Posted October 24, 2006 What's the best way to get your bonnet (hood) to fit better? Well my solution yesterday was to bend it around the upright of our driveway basketball goal. It fits much better now! http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif Rob Mitchell
slngsht Posted October 24, 2006 Posted October 24, 2006 Mine is a little bent out of shape too, but it also has a huge hole in the middle
solder_guy Posted October 24, 2006 Author Posted October 24, 2006 Mine is a little bent out of shape too, but it also has a huge hole in the middle That's a ventilation feature! http://www.usa7s.com/aspnetforum/images/emoticons/wink5.gif Yesterday I discovered that there is a horn button in the center of my steering wheel. http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif And there is a tension pin in my dash making contact with the spacer. So I have all that is necessary to have a centrally fuctional horn! But the horn innards were corroded. So today with just a little sanding, the button switch is in perfect functional shape! Plus I added some electrical grease to prevent future corrosion. A centrally located horn I shall have and use frequently! http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif Rob Mitchell
solder_guy Posted October 31, 2006 Author Posted October 31, 2006 Spent the afternoon at a junkyard .. just looking for stuff. I was hoping to find a spare distributer so I could find out why cyl #3 is not getting reliable spark. I did find a dual horn setup .. to replace the one that is broken on the Rotus. I still need to wire it to the button in the center of the steering wheel. That will require a relay to activate. I also found another brake fluid float cap. I have two now .. just need one more and I can wire them up to a lamp in the dash to detect low fluid in one of the three master cylinders. Why does work interfere with Project Rotus?? UPDATE: For some reason the mechanic had crossed spark wires 2 & 3. http://www.usa7s.com/aspnetforum/images/emoticons/confused5.gif Now the engine runs much more reliably! http://www.usa7s.com/aspnetforum/images/emoticons/hurray.gif Rob Mitchell
Boxologist Posted October 31, 2006 Posted October 31, 2006 hella supertones. one of the few things that will be louder than A se7en.
solder_guy Posted October 31, 2006 Author Posted October 31, 2006 Hella Supertones. one of the few things that will be louder than A se7en. I like these! Thanks for the suggestion! 118 dB! http://www.usa7s.com/forum/uploads/20061031_143114_supertone.gif Rob Mitchell
slomove Posted October 31, 2006 Posted October 31, 2006 I got the WOLO "longhorn" from Amazon for $24. http://www.wolo-mfg.com/417c.jpg I had to shape (flatten) the trumpets with a hot air gun to fit behind the grille. Very nice impressive big rig sound. But like all compressor horns there is a noticable reaction time. Gert
slngsht Posted October 31, 2006 Posted October 31, 2006 I have one loud pipe on each side attached to the gas pedal http://www.usa7s.com/aspnetforum/images/emoticons/smash.gif
slomove Posted October 31, 2006 Posted October 31, 2006 I have one loud pipe on each side attached to the gas pedal http://www.usa7s.com/aspnetforum/images/emoticons/smash.gif Ah, good idea....but don't you get a speeding ticket every time you honk? http://www.usa7s.com/aspnetforum/images/emoticons/biggrin5.gif
slngsht Posted October 31, 2006 Posted October 31, 2006 I have one loud pipe on each side attached to the gas pedal http://www.usa7s.com/aspnetforum/images/emoticons/smash.gif Ah, good idea....but don't you get a speeding ticket every time you honk? http://www.usa7s.com/aspnetforum/images/emoticons/biggrin5.gif http://www.usa7s.com/aspnetforum/images/emoticons/rofl.gifslngsht2006-11-19 14:40:00
solder_guy Posted November 8, 2006 Author Posted November 8, 2006 http://www.usa7s.com/forum/uploads/20061031_143114_supertone.gif Got these mounted on the front behind the grill / nosecone. Man are they loud! 118 dB! I had to do some drilling of brackets and soldering to make a dual wiring harness. They look great behind the grill! Rob Mitchell
solder_guy Posted November 19, 2006 Author Posted November 19, 2006 Got a new row of LEDs for the CMHBL third brake light. Gotta drill into the rollbar to mount. Getting the original seatbelts bolted in place finally. Grade 8 hardware. Maybe go for a spin around the block tomorrow. Rob Mitchell
solder_guy Posted December 3, 2006 Author Posted December 3, 2006 Low profile 28 LED stip is mounted on the roll bar as a CHMSL third brake light. Looks great. Pic to follow. Fooled around with the dual carbs again .. no progress .. still wants to die at low idle. Rob Mitchell
No_6 Posted December 4, 2006 Posted December 4, 2006 Where did you order that LED strip from? I've been wanting to get one of those.
solder_guy Posted December 11, 2006 Author Posted December 11, 2006 Where did you order that LED strip from? I've been wanting to get one of those. This is the one that I chose off eBay. 28 LEDs. They mention that one has been mounted to a Lotus: http://www.usa7s.com/forum/uploads/20061211_083730_LED_10_J.jpg >10" LED Third brake light Rob Mitchell, Atlanta, GAsolder_guy2006-12-11 08:39:24
Al N. Posted December 11, 2006 Posted December 11, 2006 FWIW, I went with a Wolo LED unit based on another sevener's recco... http://www.wolo-mfg.com/light.htm Scroll down to LTB-10.
JohnCh Posted December 11, 2006 Posted December 11, 2006 Here is a pic of the Wolo installed on my roll bar http://home.comcast.net/~cobar/bootlid-600.JPG Edited with a smaller photo. The original is >here -JohnJohnCh2006-12-11 12:45:03
