slngsht Posted May 5, 2009 Share Posted May 5, 2009 yup, the stupid mod had to approve the images. Link to comment Share on other sites More sharing options...
RGTorque Posted May 5, 2009 Author Share Posted May 5, 2009 small update. more parts to go on the car http://usa7s.com/vb/picture.php?albumid=6&pictureid=39 car in the shop getting taken apart http://usa7s.com/vb/picture.php?albumid=6&pictureid=40 http://usa7s.com/vb/picture.php?albumid=6&pictureid=37 Link to comment Share on other sites More sharing options...
scannon Posted May 5, 2009 Share Posted May 5, 2009 small update. more parts to go on the car http://usa7s.com/vb/picture.php?albumid=6&pictureid=39 car in the shop getting taken apart http://usa7s.com/vb/picture.php?albumid=6&pictureid=40 http://usa7s.com/vb/picture.php?albumid=6&pictureid=37 Pictures didn't show up again. Link to comment Share on other sites More sharing options...
slngsht Posted May 5, 2009 Share Posted May 5, 2009 http://www.usa7s.com/vb/picture.php?albumid=6&pictureid=39 Link to comment Share on other sites More sharing options...
slngsht Posted May 5, 2009 Share Posted May 5, 2009 Ok, I think the reason pics are not posting now is that the link is like this: http://usa7s.com/vb/picture.php?albumid=6&pictureid=39 it works when I add www to it like this: http://www.usa7s.com/vb/picture.php?albumid=6&pictureid=39 I will look into it tonight to fix the missing www problem. Link to comment Share on other sites More sharing options...
RGTorque Posted May 6, 2009 Author Share Posted May 6, 2009 some blood and a few hours later the oem miata manifold is finally out. also we picked the location of the turbo and planned how the cooling plumbing will look. http://img7.imageshack.us/img7/1731/cimg2662resize.jpg Link to comment Share on other sites More sharing options...
RGTorque Posted May 8, 2009 Author Share Posted May 8, 2009 (edited) updates, so we have planned out how we are going to plumb water and coolant to the turbo. also planning on rerouting the thermostat to the back of the head in the future for more efficient coolant flow. the turbo header is also growing. there seems to be less room then we previously estimated so now the turbo will be mounted on some funky angle and hopefully it will clear the frame and hood. im not extremely excited about the way ports 1 and 3 will flow because of the piping but i think for how much flow i will require it will be fine. also im told that in the joints where it splits 4 ports to 2 ports the diameter of the pipe being used is smaller and better... something about decreasing the size of the piping causing the exhaust to increase in speed. im still shooting for pull boost at 2700-2800rpm. http://img13.imageshack.us/img13/8996/cimg2664resize.jpg http://img13.imageshack.us/img13/6462/cimg2665resize.jpg Edited May 8, 2009 by RGTorque Link to comment Share on other sites More sharing options...
slngsht Posted May 8, 2009 Share Posted May 8, 2009 looking good. Link to comment Share on other sites More sharing options...
RGTorque Posted May 10, 2009 Author Share Posted May 10, 2009 update from friday http://img164.imageshack.us/img164/9436/cimg2676resize.jpg http://img164.imageshack.us/img164/9460/cimg2678resize.jpg Link to comment Share on other sites More sharing options...
RGTorque Posted May 14, 2009 Author Share Posted May 14, 2009 slow goin at the fab shop. owner was sick for a few days so it seems like i wont be bringing the car to carlisle. in fact i think i will be happy if i make it the the next autox event at this rate . current progress: ~turbo in its final location ~oil/water lines are being routed ~intercooler being test fitted ~planing air plumbing ~new autometer sport comp 2 gauges have arrives ~planning new hole in dash for boost gauge pardon low quality pics, i only had my cell phone http://img11.imageshack.us/img11/9291/dsc00559bjg.jpg http://img11.imageshack.us/img11/5483/dsc00558tzs.jpg Link to comment Share on other sites More sharing options...
7evin Posted May 20, 2009 Share Posted May 20, 2009 WOW..... What a project.... And I thought I had no room under our hood.... U da Man Roman u da man.... You might want to reroute that oil line just underneat the waste gate rod. It might get to hot where it is located. Awesome project.. Are you going to ceramic coat that header to keep the heat in it? Cheers 7evin Link to comment Share on other sites More sharing options...
RGTorque Posted May 20, 2009 Author Share Posted May 20, 2009 updates updates!!! http://img196.imageshack.us/img196/9016/cimg2709resize.jpg http://img30.imageshack.us/img30/728/cimg2710resize.jpg http://img200.imageshack.us/img200/9451/cimg2713resize.jpg http://img32.imageshack.us/img32/4889/cimg2719resize.jpg after a few delays we are back on track done since last pics: ~ turbo header completer, exhaust side now pointing straight into the exhaust system. ~ cut 1/4 inch off top and bottom of the intercooler ~ ran turbo oil feed line ~ made/installed egr block off plate ~ welded up new thermostat housing (no longer in front!) ~ cut/ rewelded water outlet ~ turbo exhaust flange has been started ~ flange made for water on turbo and fitting installed ~ figured out how all my coolant and oil will be flowing ~ ordered all silicone hose (blue), alum piping, clamps (t bolt?), and new coolant hose (blue). no skip im not trying to copy off of you... but red seems to be harder to get then i expected. to do: ~ finish exhaust flange to exhaust pipe ~ cut trim the intake manifold to fit the next item on the list ~ weld new outlet onto radiator (coolant will flow out of the back of the motor, around the intake manifold side of the motor, across the top of the radiator and into the new flange. reason for this is that there is to much pluming going on on the left and i dont want coolant running neat the turbo header. ~ weld piping onto the two aluminum flanges shown bolted on (bends need to be rather tight, so we rather weld then use hoses) im sure there is more.... Link to comment Share on other sites More sharing options...
RGTorque Posted May 20, 2009 Author Share Posted May 20, 2009 http://img188.imageshack.us/img188/4947/cimg2716resize.jpghttp://img190.imageshack.us/img190/5467/cimg2717resize.jpg spotted this charger in the shop... it was HUGEEEEEEEEE Link to comment Share on other sites More sharing options...
7evin Posted May 22, 2009 Share Posted May 22, 2009 I think you need to get rid of the blue logo on the radiator and make it say EviL R instead... Cheers 7 Link to comment Share on other sites More sharing options...
Hank Posted May 22, 2009 Share Posted May 22, 2009 Silly 7evin, the radiator is hidden behind the intercooler! He needs to put Evil R on the intercooler. Link to comment Share on other sites More sharing options...
7evin Posted May 27, 2009 Share Posted May 27, 2009 What was I thinking....... Ahhh ...I wasn't.... Link to comment Share on other sites More sharing options...
junior Posted May 30, 2009 Share Posted May 30, 2009 (edited) Yah, I used to have a turbo that was full boost at 2600 rpm. Boy did that make the car sqirly. It just came on boost to soon before the car had built up speed and spooled to fast. What a mess. Made the car fun to drive, but not fun to drive all in the same. Lag is your friend when it comes to traction. I now run a 57 mm turbo that see's full boost at 4400 rpm and the car is SO much better to drive. I would never go back to a small turbo in this particular car. Then people say " well what about the lag". Huh? These cars are so light they scoot right along even with no boost. That would be like saying putting a big turbo on a viper some how GAVE IT "lag".....yah, I guess if you call 400 lb feet torque at 2100 rpm lag. Remember you can't take away from the fact the viper made that power before the turbo was even introduced, same with our little lotus's. Even in N/A they are quick.... Once your done with your set-up you will have to let us now how the traction is with a small turbo. Glad I got away from that nightmare. J. R. Edited May 30, 2009 by junior Link to comment Share on other sites More sharing options...
RGTorque Posted June 4, 2009 Author Share Posted June 4, 2009 update! got some of the plumbing in. the bends arnt quite as sharp as we would like in some locations but i think it works out good. http://img19.imageshack.us/img19/2283/cimg2737resize.jpg http://img19.imageshack.us/img19/8995/cimg2738resize.jpg Link to comment Share on other sites More sharing options...
Boxologist Posted June 4, 2009 Share Posted June 4, 2009 are u going to get all the pipin coated once its up and running? Link to comment Share on other sites More sharing options...
RGTorque Posted June 4, 2009 Author Share Posted June 4, 2009 we will see how much $ is left. the turbo header, turbo, downpipe will be done for sure. this season im looking for function. will make it pretty over the winter. Link to comment Share on other sites More sharing options...
