Not a Good Last Run of the Season
Spaz
Took the 7 to a friends for winter storage a few weeks ago...
The trip did not end well. Luckly this happened only 2 block from his house and not going down the highway.
Good news, a replacement motor is on the way.
Edited by Spaz
Hey-so what the H... happened to your engine already? Big hole in the side. I thot those BUSA engies were bullet proof. What's the redline, 12K? Did you try !4K?
Hopefully they are plentifull and cheaply replaced tho I am sure it's a huge PITA.
It's not a Busa motor, it is a Honda CBR 900 motor. I will hopefully know next summer what went wrong in this motor when I take it apart. My guess is the oil pump went out or I got too many G's making a left hander and pushed all the oil to one side.
Thanks for caring slngsht :)
Edited by Spaz
Just been really busy at work, so forum surf time is limited. Sorry about the block.
Our FSAE car did that a few times. Never a good feeling.
Ow..thats nasty!
Educate me here, what punched that hole out? rod, piston...?
Do you plan to upgrade to a new bike motor as a result of this? Hayabusa powered maybe?
Like everyone said, it was a rod, here are a few pictures of the lower part of the rod and the block that I picked up off the street.
The replacement motor that will be going in will be the same as before, basically a 1993-1999 Honda CBR 900RR motor. Someday I would like to put a bigger CC, fuel injected motor in, but for now I just need to get it running for next summer.
In the UK there is a race class, class C in the 750 Motor Club in RGB (Road Going Bike-engined) that the spec is for carb'ed Fireblade motors.
Sorry for your loss, but at least you have all winter to get it running. I don't run baffles but run the oil level a little higher in the glass window.
Here's an idea for your Christmas list.
http://www.fluke-motorsport.co.uk/honda-fireblade-2003-sump-baffle-p-1063.html
I was told the difference between a 900cc and 1000cc is a huge difference in drive ability because of the torque. I don't want to convince you to upgrade but unless their is a cheap spare sitting beside the car look into a liter engine.
Thanks for the link. I have contacted Andy @ http://www.abperformance.co.uk/ and hopefully will have one soon. The replacement motor arrived yesterday. My motor does not have a window, just a dip stick, but nonetheless I will run a little more oil in this motor. I e-mailed Stuart Taylor and they said and I quote "totally different - don’t go there !" When asked about going from carb'ed to fuel injected. The car budget is low, so maybe in a few years I will upgrade.
