  • Replies 44
Posted Images
If someone could point me to some books or reference materials on "rising", "falling" and "neutral" I would appreciate any help. I'm just going by seat of my pants on this one.
I can understand using/replicating as much S2000 suspension parts as possible... My 7, with an S2000 motor and Subaru independent rear end, weighs 1450lbs. There are no sway bars and I can't imagine the need for one (front or rear).
Got a feeling your car will be approximately the same weight and that bar will be way overkill and may negatively affect handling. You can always use it as a template for a smaller diameter one should you feel it's needed after completion.
It should be noted I have no engineering or mechanical backround so my comments are more for you to get a second opinion then to actually go by what I say;)
That rear shock set up looks trick and I'm sure you can get it dialed in with a little research. Keep up the good work!
Hard to be sure from the photo above since it's not a pure "straight on" view, but that rear rocker looks to have a serious falling rate ratio that you may want to reconsider. Also, you might consider triangulating those rockers themselves. I'll see if I can find a photo of the ones on the race car.
worked, see below
I love the suspension set up. Do you have any issues with your shocks over heating
in a race. I have seen shocks get so hot that they blue the rod.
One of the advantages of having them out in the air is cooling
Dale,
Though you can go through the math and figure things out, there is an easier way since you have something physically built. Take the coil off the shock (I'm assuming you can do this easily), disconnect the sway bar, and take the wheel off. Starting at full droop, move the suspension in small increments, say 1/4" at a time. At each position measure the shocks eye to eye length. Once you have done this for the entire suspension travel, you can plot on a graph wheel travel versus shock travel. This is easily done in Excel.
A falling rate is when the shock travel is progressively less relative to wheel travel as you go from full droop to fully compressed. Rising rate is the opposite.
Now the likely next question is, what should I be aiming for? That's tough to give a definative direction on.
I would suggest that before you do anything, you also determine whether the front is falling or rising rate. I would suggest a good place to start is the reasonably closely match them, and to try to get near neutral, though most 7 front suspensions with canted outboard shocks are slightly falling rate.
Hope this is of some help.
Have fun.
BTW, I agree that Carrol Smith's series of books are a great reference and a good place to start.
Jack
Wow,
I'm sure suspension can be really complicated, but Jack, that's one of the most simple, logical and easy to understand suggestions I've seen. Good job!
Wow,
I agree with you Mondo, Brief, and very clear.
Kudos Jack
  • 6 months later...
Had an accident in Feb. Plate and 11 screws make it functional again.
http://lambobuilder.com/LS7/chassis/suspension/wrist.jpg
Redid rear suspension ass suggested
http://lambobuilder.com/LS7/chassis/suspension/rearShockswiv1.jpg
http://lambobuilder.com/LS7/chassis/suspension/rearCoils1.jpg
http://lambobuilder.com/LS7/chassis/suspension/rearCoils2.jpg
Got the front mocked up as well
http://lambobuilder.com/LS7/chassis/suspension/front3.jpg
http://lambobuilder.com/LS7/chassis/suspension/frontFin1.jpg
http://lambobuilder.com/LS7/chassis/suspension/front1.jpg
http://lambobuilder.com/LS7/chassis/suspension/frontFin3.jpg
Wow! Hope your feeling better.
Topnotch work your doing. Kind of surprised you didn't do a similar thing with the front suspension and go for a cleaner look with an inboard-shock design (doubt any of us could tell the difference in handling).
Keep up the good work. Wish I had your skills... look forward to more progress.
Dale:
Wow! That's a pretty complicated left wrist repair .. I'm glad you are back at your game. It's great to see progress on your car ..
Rob
  • 3 weeks later...
  • 3 years later...
  • 1 month later...
  • 4 months later...
