Ruadhd2 Posted May 4, 2010 Posted May 4, 2010 My Rotus has just two rusty clamps holding the bonnet on. I was wondering what variety of hold-down systems are easiest to use and install. I was going to go with one forward and aft on the bonnet on each side instead of just two. Also, I want to get these chosen before going to do the bodywork and paint on the car.
TheDingo8MyBaby Posted May 4, 2010 Posted May 4, 2010 Here's a good source for all different types of latches http://www.pegasusautoracing.com/group.asp?GroupID=LATCH
JohnCh Posted May 4, 2010 Posted May 4, 2010 Check out Protex. Lots of options and good quality. -John
Dave Posted January 25, 2011 Posted January 25, 2011 Some tool box style latches work well and are dirt cheap http://www.istockphoto.com/file_thumbview_approve/6519330/2/istockphoto_6519330-toolbox-latch-macro.jpg
Kitcat Posted January 26, 2011 Posted January 26, 2011 Two? I am all for adding lightness but I'd go w/4, one at each corner. I recall a video here of a "bonnet" blowing off at speed and nearly decapitating the driver!
danilo Posted January 26, 2011 Posted January 26, 2011 Try Aircraft spruce. "Cessna latches" are good and v light Work 'fine' on my 152 as well as tens of thousands of Cessnas, worldwide. Surprisingly pricey though http://www.aircraftspruce.com/search/search.php I had those big Rubber stretchy hold downs on my old S2, worked fine, if a bit ungainly looking.
RossD Posted January 26, 2011 Posted January 26, 2011 http://www.mcmaster.com/#about-draw-latches/=arfzvr Or just check your local hardware/home depot store.
powderbrake Posted January 27, 2011 Posted January 27, 2011 Here's a good source for all different types of latches http://www.pegasusautoracing.com/group.asp?GroupID=LATCH I have this #3045 ( or it's equivalent) on my Ultralite. Very durable and reliable and adjustable.
