escondidoron Posted July 5, 2010 Posted July 5, 2010 I'm interested in installing a 5-speed behind my old pre-crossflow in my '62 Seven and have lots of questions regarding this upgrade. I should note that I don't want to make any serious chassis mod's if I don't have to as I would like to be able to put everything back to original if I ever decide to sell the car. I have good fab skills and a decently equipped home shop. Making mounts, revising the hydraulic system for a different clutch, some new aluminum panels and a new drive shaft doesn't scare me. I am thinking that a T-9 is probably the easiest path forward. So here goes with the questions: 1) Has anybody here upgraded from the Ford 4-speed to a 5-speed behind either a pre-X-flow or an X-flow? 2) Is it true that the pre-X-flow has the same bolt pattern on the block as the later X-flow / Pinto / Zetec? 3) Knowing that the current Miata uses the Duratec I started wondering if a Miata box is a possibility? I'm guessing that it is not, but I thought it to be worth checking out due to the relatively easy availability of Miata parts here. 4) Is the T-9 the best / only cost-effective option to pursue? 5) Are there different T-9 housings or are they all the same regarding; a) overall length b) transmission mounting c) shifter location 6) What bellhousing is the one to use to mate the T-9 to an X-flow? 7) Is a different flywheel / starter required when swapping the transmission? 8) Is the only T-9 donor (here in the States) the XR4-Ti? or will a box out of a 4-cyl Mustang or T-Bird work (MT75?)? Any / all help is appreciated.
scannon Posted July 5, 2010 Posted July 5, 2010 Ben at Caterham USA (303 765 0247) would likely know exactly what is needed for the swap. He is a source for the T-9 transmission and other parts. The Miata Duratec uses a different transmission than the 1st and 2nd generation Miatas. Think about installing an engine and trans from a Miata as a unit. That way your original drivetrain remains intact for restoring back to original. In the meantime you gain Japanese reliability, almost unlimited power upgrades and fuel injection. As a bonus it will severely piss off the purists.
Ian7 Posted July 6, 2010 Posted July 6, 2010 I have seen many posts complaining that the standard T9 has a uselessly low 1st gear ratio and too large a gap to second. Couldn't find one to drive before deciding on my car, so I went with a Quaife box with my choice of ratios. Not cheap, but bolts right on to a X-flow. Call Taylor-Race Engineering in Texas.
