craig chima Posted July 19, 2010 Posted July 19, 2010 I have a new Caterham chassis that was going to be the basis of a still-born vintage race car project that I'd now like to sell. Absolutely perfect RHD chassis built to S2/S3 Lotus specs. This is a black powdercoated chassis, and the aluminum skins still have the blue plastic protective film on them. Ready for assembly. Will sell for the $11K that I have in it. Craig Chima (330) 807-0742 or chima97@aol.com. I'm starting to liquidate a 30+ year collection of Lotus 7/Caterham stuff so please feel free to contact me if you have any specific needs or wants.
Kitcat Posted July 19, 2010 Posted July 19, 2010 Do you have an upgraded oil pump for the Kent engine? If so, how much $? My stock oil pump manages abt 25 lbs pressure once all is warmed up. According to the most recent edition of the Lotus magazine, ReMarque, the stock pump is a weak leak in the Kent engine, low oil pressures are standard, and upgrades are recommended. Thx, Mike
Ian7 Posted July 19, 2010 Posted July 19, 2010 Do you have an upgraded oil pump for the Kent engine? If so, how much $? My stock oil pump manages abt 25 lbs pressure once all is warmed up. According to the most recent edition of the Lotus magazine, ReMarque, the stock pump is a weak leak in the Kent engine, low oil pressures are standard, and upgrades are recommended. Thx, Mike Pump is easily shimmed for more pressure. I'm currently in process of trying to iterate pressure down a bit after over-shimming to 100+ psi :-)
TheDingo8MyBaby Posted July 19, 2010 Posted July 19, 2010 Pump is easily shimmed for more pressure. I'm currently in process of trying to iterate pressure down a bit after over-shimming to 100+ psi :-) Not bad! At least considering my OEM caterham gauge goes to 8 bar.. ;-)
