Anyone have experience with this or other muffler
My rotary engine is way too hot and way too loud. Have had several exhaust systems attempted.
Flowmaster recommended this one:
Hushpower 13016100 Pro Series Muffler
Any other solutions? I bought one of Martin's cool Seven heat shields, which is 18" by 6" but expands to cover a 6 inch plus diameter muffler.
Suggestions?
No direct experience, but I know from playing with my son's RX7 that a rotary will destroy any muffler that isn't stuffed with stainless. Glass pack type mufflers will have a life span measured in blocks. I'd try looking at Burns Stainless.
Suggestions?
I have a Hushpower on mine and love it. Dropped from 109 db to 95db as measured at Laguna Seca. The shell is cooler though it is has a significant gradient with the front part of the muffler being a lot warmer that the rear section. It will save you from burning your legs especially through pants.
http://farm5.static.flickr.com/4044/4474738453_2f2c0d04cc.jpg
IMG_0057 by rnair, on Flickr
I read a couple of places that extended exposure to 95db will cause hearing loss. Is anything quieter than that but still "sporty" worthy of a 7?
I drive with a helmet and custom earplugs so the sound level isnt too bad for me. Hushpower will make you any custom muffler you want so I would recommend that you ask them to make one that will fit your specific needs. Mine is a custom one and I can probably dig up a part number for you if you;d like.
Didn't know about the custom muffler. I just bought the stainless pro model on Amazon for $139.00 and free Prime shipping, but would return it if I could get someone to build me a bigger one.
A 16" 6" diameter hi flow muffler is not going to cut it.
I recently put an Ultraflow SS unit on my Zetec Birkin and it has a low, aggressive, loud tone. :banghead:
It sounds better than the blare of a burnt out Factory Birkin exhaust but it is too loud for my taste.
m
have a 13b with a weber 48 and it was loud, now has two "turbo" style mufflers in series, noise is down to a reasonable level but so is power, and exhaust heat burns anyone who rides, being on the passenger side. my planned fix is a turbo-ll and a side pipe with heat shield and a short running board over it. Have also considered an oval 3" tail pipe as my car is almost all street and raised to be able to clear the 4" rocks that appear out of no where and get straddled. for keeping the NA would suggest the longest muffler that will fit between the wheels, either flowmaster type with baffles or with stainless wool that can be replaced. One other tip that came to me is to only use just enough octane ,(i run regular) as a rotary will be still burning the "slow" fuel in the exhaust creating more heat there. that said; i an not a rotary expert.
Would it work to put the hushmaster closer to the headers and another one under the heat shield by the passenger entry area?
Mine is a 6 inch dia and 20 inch length. Call their special projects division and they will be able to suggest the correct sizing for your application and fab it up for reasonable prices (mine was $199). The guy I dealt with was:
Lee Thompson
VP of R&D
800-544-4761 ext. 710
Feel free to mention my name (Rahul) if you'd like. Also I should mention that while car was listed at 95 db at Laguna we do believe that the majority of the noise is now from the intake rather than the exhaust but I have not yet tried a different intake to test the theory.
I replaced my stock Caterham muffler with a Hushpower. I chose it for its' small size and lighter weight. Thus far I have found it to be conversive at casual speeds and still sounds great at track speeds. Yes, I can still hear my iPod at highway speed.
On the subject of mufflers, my next try is using the C5 Corvette titanium muffler. The cut down muffler weighs (guess what 7 lbs). I will tuck it under the clam shell.
I now have a spiral muffler and Ultraflow. When I was running the BDA, it required two Ultraflow mufflers. I also have a custom made alloy airbox which directs the intake noise into the cabin.
Remember, at the "Q", we are limited to 93db @ 50 ft.
Wayne
