Guest Terry Posted October 30, 2011 Posted October 30, 2011 In our next shipment from Caterham we will be bringing in a large quantity of the only tire worth fitting to a 7, the purpose build AVON CR500. Cost will depend on how many inquiries we get. If you want to order a set we will require 50% up front via Pay Pal and the balance when they hit our shop. We will only sell them in quantities of 4. You can get your own shipping quote. They will be shipped from T4N 6P7. Watch this space for more info. Size 195x45 15 ware rate is 20. Terry
Birkin42 Posted October 30, 2011 Posted October 30, 2011 Are you only bringing in 195x45-15's or other sizes as well?
jlumba81 Posted October 31, 2011 Posted October 31, 2011 +1 on the sizes. I don't supposed you'd be able to do any wheel/tire packages?
Guest Terry Posted October 31, 2011 Posted October 31, 2011 The CR500 is only made in 2 sizes. 195x45 15 175x55 13 We are only bringing in the 15 inch CR500, rims are possible. Let me know what you are looking for.
blubarisax Posted October 31, 2011 Posted October 31, 2011 Great tires, I've got them in 205/55-13 and 245/50-13 and use them as my rain tires for the track and on the street.
Croc Posted October 31, 2011 Posted October 31, 2011 I second Karl on the recommendation. CR500s are really well suited to sevens. I have found them nicely progressive on the road and track. My car is currently running 195 45 R15 front and 245 40 R15 rear. I think Terry is importing the standard size that most roadsports run in the UK front and rear.
Guest Terry Posted October 31, 2011 Posted October 31, 2011 I second Karl on the recommendation. CR500s are really well suited to sevens. I have found them nicely progressive on the road and track. My car is currently running 195 45 R15 front and 245 40 R15 rear. I think Terry is importing the standard size that most roadsports run in the UK front and rear. Quite correct, larger sizes are available for the CSR. We did a test with rear CSR rims and 245's on the back of a Roadsport and it destroyed the acceleration, those large rims require a big HP motor.
Kitcat Posted October 31, 2011 Posted October 31, 2011 I have the 195/45 15's on my 220 hp Birkin and they are very nice, with progressive, predictable, balanced, controllable, breakaway. Very light weight. I didn't find them effective in the rain tho, felt like I was on slicks. Also, in 1st and 2nd gear, as I hit the power band, they break loose and the car steps out. It is not an issue at higher speeds, tho I can "steer" w/the accelerator.
Guest Terry Posted October 31, 2011 Posted October 31, 2011 I have the 195/45 15's on my 220 hp Birkin and they are very nice, with progressive, predictable, balanced, controllable, breakaway. Very light weight. I didn't find them effective in the rain tho, felt like I was on slicks. Also, in 1st and 2nd gear, as I hit the power band, they break loose and the car steps out. It is not an issue at higher speeds, tho I can "steer" w/the accelerator. One of the biggest problems that I have seen with 7 owners is their tire pressures are way to high. Changing the pressures makes a huge difference to the slip angles.
yellowss7 Posted October 31, 2011 Posted October 31, 2011 The CR500 is only made in 2 sizes. 195x45 15 175x55 13 We are only bringing in the 15 inch CR500, rims are possible. Let me know what you are looking for. Actually they also come in a 205x55x13 for 8 and 8.5 inch rims I ran the 175x55x13 up front and the 205x55x13 on the rear of my Caterham. That was the preferred set up on the Superlight R's and R500's. Tom
Guest Terry Posted October 31, 2011 Posted October 31, 2011 Actually they also come in a 205x55x13 for 8 and 8.5 inch rims I ran the 175x55x13 up front and the 205x55x13 on the rear of my Caterham. That was the preferred set up on the Superlight R's and R500's. Tom You are quite correct, those are the race rims
Kitcat Posted October 31, 2011 Posted October 31, 2011 Terry: I typically run 18 lbs rear, 16 front, cold. What do you recommend?
Guest Terry Posted October 31, 2011 Posted October 31, 2011 Terry: I typically run 18 lbs rear, 16 front, cold. What do you recommend? I would say you are spot-on. :hurray:
MoPho Posted October 31, 2011 Posted October 31, 2011 Actually they also come in a 205x55x13 for 8 and 8.5 inch rims I ran the 175x55x13 up front and the 205x55x13 on the rear of my Caterham. That was the preferred set up on the Superlight R's and R500's. Tom It was recommended to me by Caterham not to run the bigger rear tires unless you have 250hp or so. My Superlight R has the 195's around. If the price is right, I am in need of a set of tires, but I imagine having to ship them from Canada is going to negate any savings .
MoPho Posted October 31, 2011 Posted October 31, 2011 Also, in 1st and 2nd gear, as I hit the power band, they break loose and the car steps out. It is not an issue at higher speeds, tho I can "steer" w/the accelerator. Yup, ain't it great!!! .
jlumba81 Posted November 4, 2011 Posted November 4, 2011 (edited) Well I'm interested in a set of 195/45r15. PM me when you have the pricing figured out. Do you have an ETA on when you will have the tires? Also what do you have over there for shipping? I couldn't get a quote thru fedex or ups. I'd have to call them but need details on the weights and dimensions. Forgot to add that I'm looking for minlite style wheels that have the proper offset. Edited November 4, 2011 by jlumba81
Kitcat Posted November 14, 2011 Posted November 14, 2011 Are Avon CR 500's only available in England? Or, is there a USA dealer?
pksurveyor Posted November 14, 2011 Posted November 14, 2011 http://www.rogerkrausracing.com/ http://www.sascosports.com/
blubarisax Posted November 14, 2011 Posted November 14, 2011 I got mine from Roger Kraus Racing on a special order (a few weeks) and they were great to deal with. They stock a limited supply of Avon slicks too.
Kitcat Posted November 14, 2011 Posted November 14, 2011 Thx guys. As you know Karl, I put a hole in the side of one of mine Saturday, while also bending the wheel. First time I ever hit a pile of rocks when sliding off a racetrack. You'd think they wld remove them? Much nicer to just get grass stains on the tire, as I did in a subsequent slide off elsewhere. Of course, even nicer to stay on the track....
