Avon cr500
In our next shipment from Caterham we will be bringing in a large quantity of the only tire worth fitting to a 7, the purpose build AVON CR500. Cost will depend on how many inquiries we get. If you want to order a set we will require 50% up front via Pay Pal and the balance when they hit our shop.
We will only sell them in quantities of 4. You can get your own shipping quote. They will be shipped from T4N 6P7.
Watch this space for more info. Size 195x45 15 ware rate is 20.
Terry
The CR500 is only made in 2 sizes.
195x45 15
175x55 13
We are only bringing in the 15 inch CR500, rims are possible. Let me know what you are looking for.
I second Karl on the recommendation. CR500s are really well suited to sevens. I have found them nicely progressive on the road and track. My car is currently running 195 45 R15 front and 245 40 R15 rear. I think Terry is importing the standard size that most roadsports run in the UK front and rear.
Quite correct, larger sizes are available for the CSR. We did a test with rear CSR rims and 245's on the back of a Roadsport and it destroyed the acceleration, those large rims require a big HP motor.
I have the 195/45 15's on my 220 hp Birkin and they are very nice, with progressive, predictable, balanced, controllable, breakaway. Very light weight. I didn't find them effective in the rain tho, felt like I was on slicks.
Also, in 1st and 2nd gear, as I hit the power band, they break loose and the car steps out. It is not an issue at higher speeds, tho I can "steer" w/the accelerator.
One of the biggest problems that I have seen with 7 owners is their tire pressures are way to high. Changing the pressures makes a huge difference to the slip angles.
195x45 15
175x55 13
Actually they also come in a 205x55x13 for 8 and 8.5 inch rims I ran the 175x55x13 up front and the 205x55x13 on the rear of my Caterham. That was the preferred set up on the Superlight R's and R500's.
Tom
Tom
You are quite correct, those are the race rims
Terry:
I typically run 18 lbs rear, 16 front, cold. What do you recommend?
I would say you are spot-on. :hurray:
Tom
It was recommended to me by Caterham not to run the bigger rear tires unless you have 250hp or so. My Superlight R has the 195's around.
If the price is right, I am in need of a set of tires, but I imagine having to ship them from Canada is going to negate any savings
Yup, ain't it great!!! :D
Well I'm interested in a set of 195/45r15. PM me when you have the pricing figured out. Do you have an ETA on when you will have the tires? Also what do you have over there for shipping? I couldn't get a quote thru fedex or ups. I'd have to call them but need details on the weights and dimensions.
Forgot to add that I'm looking for minlite style wheels that have the proper offset.
Edited by jlumba81
I got mine from Roger Kraus Racing on a special order (a few weeks) and they were great to deal with. They stock a limited supply of Avon slicks too.
Thx guys.
As you know Karl, I put a hole in the side of one of mine Saturday, while also bending the wheel. First time I ever hit a pile of rocks when sliding off a racetrack. You'd think they wld remove them? Much nicer to just get grass stains on the tire, as I did in a subsequent slide off elsewhere. Of course, even nicer to stay on the track....
