slngsht Posted January 24, 2006 Posted January 24, 2006 Anybody use Odyssey batteries? They have a full lineup, but the lightest is this one: Small 680 cranking amp battery with metal jacket and SAE automotive terminals. Also available without the metal jacket for low temperature applications. Battery measures 3.11" wide x 7.27" long x 6.67" tall with the metal jacket and weighs 15.4 pounds. http://www.odysseybatteries.com/battery/pc680mjt_lg.jpg Recognize that the reserve rating is small, so storage time with computer draw can discharge the battery in a few weeks. Ideal for Street Rods up to 5.7 liter V-8. Can be mounted in the glove box flat on its back - only 3 1/8 inch high. Excellent starting battery where high reserve capacity is not required. Great lightweight racing battery for shedding extra pounds. Can be mounted upright or flat.
slngsht Posted January 24, 2006 Author Posted January 24, 2006 Their other batteries can be found here: > http://www.odysseybatteries.com/applications/auto.htm#bcigro up
JohnCh Posted January 25, 2006 Posted January 25, 2006 I have a PC680 and it works great. No problem doing multiple starts or starting in cold weather (32F). It also has plenty of charge left to fire up the engine after a 3 week layoff, but I have not tried going longer than that without hooking up the battery to the charger (you need a special type of this kind of battery). This type of battery doesn't like heat, so it is best to mount it away from the exhaust system. I mounted mine in front of the driver's side footwell on the lower chasis rails to keep the center of gravity low (the Duratec exhaust exits on the passenger side of the car) -John
slngsht Posted January 25, 2006 Author Posted January 25, 2006 John, it's good to know someone else has used them. My battery is currently mounted on top of the passenger side footwell. Engine is a V8, so I have exhaust on both sides, but it exits with a quick 90 from the manifold, and is very low on the car - hopefully it'll be fine.
solder_guy Posted February 2, 2006 Posted February 2, 2006 I ordered my Odyssey 680MJT today and it will be shipped to Dennis Hedges at Short Mountain Enterprises. I was looking at the EnerSys website about the Odyssey. A special charger is not necessary. They suggest a 6-7A charger which maintains at least 14.2 volts but not more than 15 volts while charging. It must go to trickle after fully charging the battery or be disconnected after 2 hours if using a manual 10A charger. >Odyssey Charging Information Dennis says that this Odyssey 680 is cranking Mazda's V8 really well! Rob Mitchell
JohnCh Posted February 2, 2006 Posted February 2, 2006 I was looking at the EnerSys website about the Odyssey. A special charger is not necessary. They suggest a 6-7A charger which maintains at least 14.2 volts but not more than 15 volts while charging. It must go to trickle after fully charging the battery or be disconnected after 2 hours if using a manual 10A charger Right, so not just any charger. Hence the term "special" http://www.usa7s.com/aspnetforum/images/emoticons/smiley2.gif
slngsht Posted February 2, 2006 Author Posted February 2, 2006 I wonder if there is any problem with jumping them.
JohnCh Posted February 2, 2006 Posted February 2, 2006 I've never heard of a problem with jumping them, just with using a charger that exceeds 15v. There is a good website on this type of battery located >here that is worth reading. -John
solder_guy Posted February 3, 2006 Posted February 3, 2006 In summary, to maximize the life of your sealed lead acid battery do the following: -Always keep the battery charged. -Avoid deep discharges of the battery. -Use the correct charging voltage and current. -Keep the battery temperature below 77ºF (25ºC). -Never attempt to remove the top decal cover of the Genesis or Odyssey battery because this will cause the battery to fail. Well what about the 95ºF heat we have in Atlanta in the summer?? Plus the engine compartment !! Rob Mitchell
slngsht Posted February 3, 2006 Author Posted February 3, 2006 Rob, that's "Ideal". I guess I'll find out soon enough if these batteries have a short life. Even if it lasts 2 years, for me it's not too bad.
solder_guy Posted February 3, 2006 Posted February 3, 2006 I guess I'll be removing my 680MJT battery during the hottest of days and while gone on summer vacation! Rob Mitchell
solder_guy Posted October 24, 2006 Posted October 24, 2006 I just bought a Battery Charger Tender plus SUPERCHARGER 12 V 3 Amp off eBay for my Odyssey 680 Battery. It uses constant current charging instead of tapered charging and is made for the Odyssey and Optima Batteries. It comes with both washer connections and clip connections. The washer connections can be "permanantly" connected to the battery for convenient plug-in charging. Rob Mitchell
Mike Rohaley Posted October 24, 2006 Posted October 24, 2006 I installed the PC680 about a year and a half ago, I have had no problems with it while using the car as a daily driver. After I replaced the original Banner battery the car would fire up quicker with less cranking. Another bonus is that it saves about 9 lbs. (cannot remember exact number)
Al N. Posted October 24, 2006 Posted October 24, 2006 FWIW, I have one of those little C-TEK "smart" trickle chargers and it works well enough on the battery that came with the Caterham. I bought it after buying one of those big-a$$ schumacher ones that you can get at AutoZone. While I use that to jump start cars still, didn't seem as sophisticated as perhaps the Cat's battery warranted.
slngsht Posted October 24, 2006 Author Posted October 24, 2006 My Ody is holding up fine after a year, despite me completely killing it at least 5 or 6 times by keeping the OBD diagnostic port plugged in. I've just jump started it.
slomove Posted October 24, 2006 Posted October 24, 2006 I have the smaller 625 model in the Seven since I bought it (4 years and probably was in there before a while). No issues and I have had it sitting around for 6 months one time. After that it started the engine right away. Drained it a few times unintentionally but a cheap Autozone charger qualified for "deep cycle" batteries brought it back to life. I know many Se7eners are using this battery type and have heard very few complaints. Gertslomove2006-10-24 13:25:09
stevet Posted October 24, 2006 Posted October 24, 2006 I have the 680MJ also - no problems so far http://www.usa7s.com/aspnetforum/images/emoticons/thumbsup.gif
Catie Posted October 25, 2006 Posted October 25, 2006 I've used Odyssey for years...in a street Miata, in a very high compression Nissan, and in the race prepared Caterham (currently installed is the PC925). No complaints. I do use a special charger made specifically for gel cell batteries.
solder_guy Posted January 27, 2009 Posted January 27, 2009 My Odyssey PC680 died after only one season of driving the car. I bought the special charger and it will not fully charge to turn the car over at all. I am changing to a small lead acid battery that fits in a Civic. Longer warrantee .. but it weighs twice (?) as much. So I have the two Odyssey auto terminals and the 680 metal jacket up for grabs. Rob
pksurveyor Posted January 27, 2009 Posted January 27, 2009 I used an Extreme Battery AGM battery from Battery Plus for the Caterham. It is half the size and weight of the original Banner lead acid battery. I have it for over two year now. The battery can turn over the Zetec even after sitting still for 3 months without recharging. Take a look at the Battery Plus website.
