stalker77 Posted August 21, 2012 Posted August 21, 2012 Brunton Stalker 3.4L Chassis #34, 2004 Street legal and registered in Texas as 1959 Lotus Very well sorted for Auto-x and pleasant road manors. Perfect balance and tons of useable power. I've had the car for 5 years and worked out all bugs and handling issues- including nasty oversteer inherent in the design. Road driven and auto-x regularly, never wrecked or failed to drive home. Needs nothing. Perfect for the owner who is looking for a hard-core street/track car and appreciates an old-school approach to hot-rodding. Some pics posted in Members Ride section in "East Texas Stalker" I will list details in next post. Includes: Goodyear slicks, custom-built trailer, plenty of parts Asking $24,000 Car is located in East Texas and will continue to be enjoyed until sale. Contact through this post, e-mail ( yenzer@cablelynx.com ), text or call at 903-239-3870 for more info. plenty of pics and go-pro video available.
stalker77 Posted August 21, 2012 Author Posted August 21, 2012 Here are the highlights. Anything not mentioned, just ask! Motor: 3.4L GM 60 degree V6, 9:1 compression Crower solid lifter cam, .520 lift, 110 deg cl 1.6 aluminum full-roller rockers Chromoly retainers/keepers, dual springs custom hardened push rods Custom Road Race oil pan, gated & baffled, increased ground clearance Supercharger- B&M 142ci, 148% overdriven, custom manifold & drive Holly 390 cfm carb- modified, no choke, slosh control Mallory Hyfire ignition system, w/ revlimiter (set 6250 rpm), recurved distributor Holly fuel system The Rest: Weight 1560# ready to run (wet, no driver) T-5 transmission 10 bolt rear, 3.42 gears Auburn Gear "Autocross" LSD (Dramatic improvement over Torsen- I can't brag enough about this product!) Added 4-link adjustments Willwood pedals & master cylinders, bias adjustable Hawk HP-Plus pads front, rear drums AVO adjustable dampening shocks w/ 275# rear x 325# front springs Kirkey low-back sprint seats Street wheels- WELD 15 x 7 forged w/ Falcon 205-50 Comp wheels- 13 x 8 / 13 x 10 Diamond w/ Goodyear Slicks Trailer- custom built 12 ft single axle low deck w/ stone guard & 8ft custom aluminum ramps- short & light, tows splendidly! Parts: everything that came with it or was changed since I've owned it
rikker Posted August 21, 2012 Posted August 21, 2012 Doesn't all of that engine/blower/filter bursting out affect your visibility? I get bothered with a bug splat on the glass.
xcarguy Posted August 21, 2012 Posted August 21, 2012 I'm quite sure that 'old-school cool' blower will indeed affect your visibility; wind it up tight enough and it'll blur your vision. :cheers: On a serious note, can you post pics of the trailer? Thanks.
stalker77 Posted August 23, 2012 Author Posted August 23, 2012 It's funny, I was worried about visibilty issues durring mockup. As it turns out, you look "through" it when driving and don't notice it. Other drivers have said the same thing when in the car, so it's not just me. Good driving requires you to look far ahead and things close in get ignored. Wierd but true. I agree it does deviate from the traditional 7 lines but Stalkers are a unique breed ayway. The "cool factor" cannot be denied. As if one of these cars does not already command attention, this pushes it over the top. If it didn't make the car perform better however, I would have removed it and put everything back under the stock scoop. It works- it stays! Here is the trailer. Low and lean. Long ramps keep the car from hitting even with about 3" ground clearance when sitting on slicks. total weight with car loaded is about 2500 lbs. ramps fit into the trailer's bed once the car is loaded. I have pulled it at 90 mph with no concerns.
xcarguy Posted August 24, 2012 Posted August 24, 2012 (edited) Would you consider selling the trailer seperately? Edited August 25, 2012 by xcarguy
Bonjo2 Posted July 25, 2016 Posted July 25, 2016 Great looking car. Did you make the windshield? Looks awesome
