I need to sit in one before I go further
Martin
Hello Southeasterners!
I am in the greater Atlanta area (northeast) and I am heavily considering a Caterham. I am 6'2 and have a size 12 shoe. I realize that I need to have a genuine understanding of what I am getting into if I am separating so much cash from myself for a toy. Not asking for a joy ride, just some help in knowing if it is for me or not. Is there anyone that would be willing to let me sit in their driver's seat that isn't hours away?
Martin,
Unfortunately, I am five hours away, and just into Central Time; however, your post piqued my interest, as I am 6' 3" with size 12 shoes. IF you were inclined, and your finances allowed, I would suggest a Caterham 7 SV--aka "Sumo Version"--as you would have no trouble with clearance in the driver's footwell. I don't even bother with weltless driver's shoes, such as Piloti, as I have not found a need for them yet.
Good luck with your research and your search.
Taber
I'm even further away than Taber but if you happen to be traveling to or thru Denver you are welcome to sit in my SV and go for a ride, perhaps even drive it. You could also make a visit to Caterham USA while in the area.
Martin,
You may even fit in an S3 depending on your build, a long torso vs. long legs. I'm 6'6" (was 310#, lost a bit to keep up with Croc) and fit in an SV with a few modifications. I added lowered floors and a custom tall roll cage. I also modified the seat brackets to get me all the way back, then extended the steering shaft as much as possible.
You are welcome to come to NJ where you could try on one of every size.
Karl
Thanks for all the offers gentlemen. I am realizing that I will need patience throughout all of this as everything seems to be far away. I may be driving through FL this June so if I have not experinced it by then, I may need to take you up on that offer Taber.
SV's are pretty much non-existent right now, hopefully the Sring will bring some sellers out.
What abt a Stalker or an Ultralight? They have much more room than a Caterham S3 and cost the same or less. Hard to believe there are no Caterhams in the Atlant area tho.
This might be a little personal but what weight range are you? I am a fat bastard of 5'11 with a 12.5 shoe and I can still wedge into an S3 (and a Birkin and a Westfield) and drive it. Bit of a muffin top but still a mobile muffin top. I much prefer my CSR/SV but they are pretty rare as you point out. Stalkers and Ultralites also are more generously sized. So is it a long body or a wide body that you really need?
If it is just because of height then you can survive with big feet by using small race boots or other similar driving shoes and you can get a tall roll bar to cover your head.
If it is width then keep looking for an SV or other wide chassis car.
For me not personal at all.
I am 6'2 and weigh 170 soaking wet. So width is not a concern, but pedal room certainly is. I need to experience both probably, but I am guessing I will like the extra space in an SV.
I have not considered a Stalker since I like the look and closer purity of the Lotus concept with the Caterham.
ok that helps. I think you may prefer the S3. It will hold you better when driving. A large shoe size will not be a hindrance in an S3 unless you want to heel and toe in which case it may not be possible. I still cannot heel and toe in my CSR due to low pedal box vertical height for my foot. So going to an SV is not an automatic solution.
An SV is good if you are doing a lot of touring and less spirited driving as there is more room to put the elbows out and shift position.
Whether you go for S3 or SV, your height may dictate installing lowered floors or a taller roll bar. Either is desirable.
Either way this does not solve your real problem - you really need to sit in the various types and try them out. Maybe you need to make a special trip somewhere to try out multiple types. I know it is extra cost but I did it to be certain since there were no SV's or S3's around me when I bought mine.
Martin, I’m 12 miles north of Anderson SC, I have an SV, and you’re more than welcome to sit in my car for a fit.
Hi there, thanks so much! That is a huge improvement on miles. I will see what I can do to arrange a trip, I will keep you posted, thank you.
So I do plan on visiting BlueMax but I realized I might be leaving something out. I do need to find out how a fit in an SV, but a regular 7 would be a good experience to know how to compare the two. Anyone else around in the Atlanta are preferably that has an S3? Just need to borrow 5 minutes to see how I fit in the driver's seat.
  • 2 months later...
