Red Duck Posted October 18, 2013 Share Posted October 18, 2013 I am having a tiresome problem with the speedo on my new CSR260. When traveling at a steady speed, the speedo reads what I believe to be accurate. But when accelerating, the needle flutters and, under hard acceleration, it goes to zero and swings wildly. Again, when back to a steady speed it returns to normal. I have adjusted the pickup on the right rear axle. I have tried the largest gap (when the light only just comes on as it picks up each tooth), all the way to the smallest gap, and several settings in between. I don't recall if any of the settings I have tried are materially better than any other, but just know that none of them make it work properly. Any tips? Thanks, Steve Link to comment Share on other sites More sharing options...
xcarguy Posted October 19, 2013 Share Posted October 19, 2013 Just a stab here, but us the pickup area clean; road grime, etc.? Link to comment Share on other sites More sharing options...
xcarguy Posted October 19, 2013 Share Posted October 19, 2013 Sorry .... Is the pickup area clean? Link to comment Share on other sites More sharing options...
Sean Posted October 19, 2013 Share Posted October 19, 2013 Intermittent (or consistent) bouncy gauge needles on a Caterham are frequently caused by a "dodgy earth", or inconsistent ground. Not sure about CSRs in particular, but a common culprit on a S3 is the ground point under the dash on the right side where the wiper motor mounts. Worth a look, anyway. Link to comment Share on other sites More sharing options...
slomove Posted October 19, 2013 Share Posted October 19, 2013 I would go with the above mentioned guesses. The only reason I have *heard* of acceleration affecting electrical equipment performance is that at wide open throttle the absolute compression in the cylinder is higher, requiring higher voltage before the spark fires an thus more electrical noise. I know this happened to a camera pan servo setup I used to have that became a bit jittery when accelerating. I would be surprised if that is what is happening to your speedo but, well, just to mention another possibility. Link to comment Share on other sites More sharing options...
Croc Posted October 19, 2013 Share Posted October 19, 2013 Sounds similar to my - goes haywire as soon as I go above 100mph so most of the time it is useless to me. - Check the speed sensor gap and have it on the smallest setting. Is it under 1mm? - If that is done then check the earth on the speedo - Check the speedo cable - If that is turning up negative then it is not unheard of for the Speedo to be failing and need replacement. This is a very common issue on many Caterhams and a search of Blatchat should reveal the solution to be one of the 3 above. Link to comment Share on other sites More sharing options...
blubarisax Posted October 19, 2013 Share Posted October 19, 2013 100? Really Croc... Sure it's not 200??? Mine does the same above 80. Link to comment Share on other sites More sharing options...
