Birkin Sump Guard?
Chris,
That looks great! Maybe I should have kept the Birkin. :jester:
The engine wasn't getting nearly enough fuel with injectors that were way too small and a 30 gal/hr fuel pump. Even with a conservative tune and taking it as easy as I could I burned another piston:cuss:. With a bigger fuel pump, larger injectors, and a replacement low mile '11 engine I hope to be back on the road in a few weeks.
Chris
Chris
Chris, sorry to hear. :( Hope you're back on the road soon.
Chris: As you may know from my posts, my Birkin also went thru its engine very quickly (after abt 1100 miles). In my case it was oil starvation at a track day. Are you sure the injectors are your problem? Was your car built by TMW, as mine was?
Also, the purchaser of my Birkin tore down the replacement junk-yard engine that I substituted and found rust and other issues. So be careful about what you substitute for your existing Duratec.
Edited by Kitcat
Mine is a supercharged car built by TMW and the injectors were way too small for the horsepower the car was putting out. Also the fuel pump was a 30 gallon per hr unit that could barely keep up with the 40 lb/hr injectors much less the 60 lb/hr units I now have. The engine that was in the car when I received it was bad (burned piston), I knew that was the case and he supplied another engine with the car. I'm very sure I will find the same issue when I pull the head of my current Duratec; compression is way down in 2 cyls plus I am pressurizing the crank case and blowing smoke/oil from the breather. My new replacement engine came from an '11 (15k miles) and was at the recycler for less than a week when I picked it up. I passed on cheaper, lower mile engines they had but were in stock for years.
I know oil starvation can be an issue but I haven't done any track or autocross driving yet.
Chris
