:cheers: Anyone found a small battery that works well in the Caterham. Currently using a Lawn & Garden which works well but needs trickle charge for extended down times. Mine is mounted under the Webers so size is a major consideration.
I know Odyssey will be the predictable answer, but they do work. I have the 680MJ - very happy with it :thumbs:
Take a look at the personal watercraft batteries. Prices are reasonable and they seem to last as long as the Odyssey in my Se7en.
Ditto Odyssey 680MJ.
Rob
Another vote for the Odyssey 680MJ. Small in size, lightweight, and it seems like it's got enough cranking power.
Bruce
Is there a reason you do not like trickle charging? I have 6 batteries which have extended down time and all have trickle chargers- Battery Tender model.
Bruce
Odyssey PC625 (PWC format) is a quite a bit cheaper for some reasons than the other models. Although the cranking amps are lower than PC680 I believe the actual AmpHour capacity is even higher. Mine has been in the car for 5 years, no trickle charger needed. Starts up after a few months of storage no prob.
Thanks to all who responded. Bought an Odyssey 680, although didn't get it mounted in time for the Tail of the Dragon trip last weekend. Incredible weekend. Already looking forward to next year. Maybe the two pounds I save on the Odyssey will make me competitive in the autocross. :crazy:
