My Seven
  • Biography
    I have a 1996 Caterham with a 1700 Super Sprint
    Albany, NY
  • Interests
    National Ski Patrol, bicycle touring
  1. Great looking ride. Must travel like a dream.
  2. You have one fine looking Westy. The color is great. With the high power of this car, do you have much wheel spin with these tyres? What is your track tyre pressure?
  3. You need to check the horn relay and the horn fuse. Robert
  4. WESTFIELD Wheels & Tires Anyone interested in these 15’s They have 4 lugs 4 1/4" pattern -- made in England (not Chinese) Bought from WESTFIELD FACTORY. Almost 4 brand new tires (200 miles the most) 205 -15 x 50R Mickey Thompson ET STREET RADIAL. Soft compound good for street and track. https://www.onlinetires.com/products...radial+ii.html Original cost $173.00 each tire. Yours for $480.00 wheels + tires (balanced). These are seen on a Westfield, not my Caterham 7. http://i62.tinypic.com/23iwm6q.jpg These wheels do not fit on my Caterham 7. I am located in the Albany, NY area. Cell:518-265-8043
  5. What a BEAUTY! It would be great to see some photos of the dash & engine. Stay well.
  6. R500 in West Palm Beach - British Racing Green http://www.lamborghinipalmbeach.com/used/Lotus/2012-Lotus-Caterham-bd1f22030a0a00023da276ef24188bc6.htm 2012 Lotus Caterham 500R Convertible - Price: $68,951.00 Mileage: 551 VIN: SDKLDK3NS11070389
  7. Ad states: Car came from Birkin America through Texas Motor Works in Arlington Texas. Would this Zetec engine produce the stated 205hp?
  8. 1-3-4-2, counter- or anti-clockwise - seems like the setting I used. Robert
  9. Lucas ACR Style 60A Alternator RH mounting: X/flow http://www.burtonpower.com/tuning-guides/tuning-guide-pages/ford-kent-crossflow-tuning-guide/lucas-acr-style-60a-alternator-rh-mounting-acr60rh.html Part NoACR60RH Fits Engine TypeFord Cross Flow (Kent) Hope this helps. Robert
  10. Sold on ebay for $25,900.00
  11. Hello:
    I have a 1996 Caterham 3S
    Will these seat fit this model?
    I have now fixed seats.
    Where to get the tracks for your seats?
    I can drive to pick up the seats to save damage in transit.
    Thanks
    Robert
  12. I just called the dealer. Lotus 1966 Super 7 Re-Creation 2,249 miles - $15950 (Park Place, Ltd. (Bellevue, WA)) is now SOLD Robert
  13. Hello: Will this unit below,work with my small standard Caterham 7 Steering wheel? Any experience with this unit or other model that will work with my car. NRG Aluminum Gen2 Gen 2.0 Ball Lock Quick Release Black Body w/ Neo Chrome Ring http://www.ebay.com/itm/230857517125?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649 Thank you in advance for the help. Roberto
  14. For rear wings, did the Fenders-N-More company make models to fit a stock style 1996 Caterham? I want rear wings with the stock mounting holes. Were your front wings the polished stainless? What sources are current for carbon fiber wings, nose cone & half doors? Which company makes the better quality carbon products? Can I use carbon fenders & nose from a Birkin on my 1996 Caterham? Thanks, Robert
  15. Things I have checked, yet, still over heating. 1) Is there any loss of coolant when the temp is high? NO Are either or both of the radiator hoses hot when the temp gauge says high temp? If the hoses are not hot there is likely no coolant flow. Hoses are hot. 2) Check for coolant flow by removing the thermostat, and running the engine with the radiator cap removed. If there is flow the pump is likely good. Flow is there with cap off. 3) With the radiator cap removed examine the coolant. Are there bubbles in the coolant. If so it would indicate that there is a blown head gasket. No Bubbles 4) Remove the temp sender and place it in boiling (or as close to boiling as possible) water while powered up and connected to the car. Does the gauge read correctly? Have yet to do. Other items??? There is an S.P.A. Oil Cooler in front of the radiator. Should this be hot if the water radiator is hot? It is not hot. The car came with an Accusump 2 quart Electric Pressure Accumulator with Moroso 23907 12-Volt Solenoid Pressure Valve Kit. Thanks, Roberto
