Kitcat started following 7 Cockpit Heaters, Why? , I need Caterham parts . . . is Sevens & Elans still in business? , Christmas Gifts to Our Cars and 7 others
I recall an ancient comment (urban legend?) to the effect that inside wheel spin can help the car rotate better in turns? At least on mildly powered cars. My Xflow had 96 hp and occasional inside wheel spin at track days, with wide, sticky track tires. It seemed to suit the car’s softer street set up and did not hurt lap times. And it added lightness….
Kitcat replied to savagete2860's topic in General Sevens Discussion
Most trailers come with cheap bias plied tires that are prone to flats. So always carry a spare(or 2). My first trailer upgrade was replacing its standard bias plied trailer tires with high quality radial ones. Also, many trailer tires have a maximum speed rating of 65 mph. It’s worth checking that rating before choosing a replacement or, when renting a U-Haul. -
I used a VW Touareg to tow my Caterham. It has a rating of 7700 lbs and the footprint of an Accord. It was the only tow vehicle my wife would drive. The Touareg has been replaced by the Atlas in the VW lineup with the same tow stats. The tow package option is a must. -
Kitcat replied to Croc's topic in Cars For Sale
Bruce: that is one clean engine bay! -
It appears James @ Throttle House ended up buying a 7
Kitcat replied to Vovchandr's topic in General Sevens Discussion
As a member who transitioned from 15 years of 7 ownership to a Miata, I have to say: I agree with James and could not have said it better (tho I could have said it worse, and probably would have…), My ‘19 Miata(MX-5) is infinitely easier on my 78 year old body, especially at the track (where it is 5” a lap slower than my Caterham). And that’s after upgrading its brakes, suspension and adding super wide track tires. And Mr M, that’s a great topic, but it needs its own thread, it’s going to get lost here(IMHO). -
You probably can clarify with Josh. Good luck with the sale. It is quite a car! Edit: the price there is now $89,900.
Currently listed on consignment at Rocky Mountain Caterham for $85K.
My ‘97 Caterham’s x-flow would go about 5K miles before the engine mounts were shot. So on hard turns at track speeds the engine would shift. This would cause the intake stacks to press against the cutout in the bonnet (hood). That would cause an air leak in the intake system. That would cause sputtering that would resolve as soon as the curve ended. Only took about a year to diagnose:). I think forum member BBall came up with this diagnosis in the course of chasing a corner sputter in his X-Flow. All in the FWIW category.
As the (admittedly biased) former owner, I think I can confirm this is great track car. Its superpower is safety. The cage is incredibly stout. And unlike the Caterham branded cage, it extends about 6” from the body on the driver’s side. So there is built in crush space on the driver’s side (essential if you are T-boned). And on most Caterhams your left elbow is actually slightly outside the body of the car! The FuelSafe gas tank provides protection against rear end collisions, unlike a stock(bumper-less) Caterhams). The final layer of protection is the fire suppression system. It may need a charge, as Croc suggests. When I bought it, it was a worn out race car. So I spent a sizeable amount of money bringing it back to par. I used to joke that the only thing I hadn’t replaced was the battery, and then I replaced it…. The 6sp transmission is original but I spent $$$ trouble shooting and resolving various shifting glitches. The only feature not included in the description (I think) is the presence of an oil cooler behind the top of the radiator. It takes premium gas(92-94 octane). I ran race gas when I was able to find it. Obviously it’s totally dialed in for the track and can give the mighty Duratec engined Caterham 420’s a scare.
Help needed from the community to review a future BaT listing
Kitcat replied to Pokey's topic in Cars For Sale
I may have missed it, but this car also has the Caterham 6 sp transmission and LSD. Also, FWIW, the 2 cars that placed ahead of it at the ThunderHill endurance race were Porsche Cup race cars. Hardly an even match! One of the most common questions on a Caterham BAT sale is: Will I fit? So a rough estimate of driver size limits, including shoes, might be helpful? Total vehicle mileage is also a standard question. Given its race history and absent odometer it’s impossible to know. I’d guestimate that I put approximately 2,000-3,000 miles on it during my ownership, including 500( illegal) street miles. -
GLWA, as they say on BAT! The description you have given seems complete to me. It might be worth adding that it has a fire suppression system? The removable steering wheel is a minor but vital part of the car’s set up. It has an uprated brake system with (hard to source) larger rear rotors. We switched from a “returnless” fuel system to a return system, at no small cost. I think the biggest question will be what it would cost to make it street legal? I don’t know but have to assume it is possible. I’m pretty sure all of the wiring is there for turn signals, etc? -
So sorry! Having experienced a bent Caterham in the past, I know it’s painful. Of course it’s great that you’re both ok. But it can turn into such a large hassle to source the often hard-to-find parts, etc. The only upside is it’s an opportunity (excuse) to make some upgrades?
After suffering through excess cabin heat during my first summer with my ‘97 X-Flow Caterham I consoled myself with the thought of how the heat would extend the driving season deep into the Fall. But when Fall arrived the excess heat was replaced by excess cold. So I turned on my trusty heater and was eventually rewarded with a small warmish spot on my right leg. After that I dressed as if I was going skiing and it worked great!
At the LOG 30, in Gettysburg PA, a few of us USA7s types shamelessly appeared in our non-Lotus7’s. It included a track day at nearby Summit Point. My instructor was an Elise owner and he took me out in my Caterham, with me as the passenger, to show me the fast way around the track. At the first turn he yelled: ”What just happened, the turn-in on this car is instantaneous!”. On the second turn he said:”I keep turning in way too early, in my Elise it takes a moment or two for the car to react to my steering input.” He was shocked at how heavy everything was in his Elise in comparison to my Caterham. FWIW: my X-Flow powered, 5 speed, Dedion on 15” tires was invariably as fast, or faster, around whatever track I was on compared to the standard Elises and Exiges there.
