Everything posted by FE07
I'm offering $100 to anyone who can solve my car's nightmarish issues
FE07 replied to Ted7's topic in General Tech
I can't respond to the car cutting out and then starting with just the clutch. That's just bizarre! I can however tell you that I also have a Zetec powered Cat that has always idled high since I've had it. Both Chip Bond (the original builder with GT classics) and George Alderman looked at it and tried all kinds of things to figure out the idle issue. Changed the seals for the intake and injectors, swapped injectors, messed with the PCV system. We swapped the stock ECU for another one and it seemed better for a little while but then ultimately returned to idle around 2200. Sometimes it will go down to 800-1000 if the car is warmed up but it's not consistent. I just live with it. The cutoff though could be dangerous. -
Thanks for the replies guys. Unfortuneately, it's a T9 without a drain plug. It's been a slow leak over the past 8 years which is what prompted me to finally look at it. Was a little less than 1/2 empty. Gearbox was working fine. Think the only way for me to empty it full will be from the top. Put the drain plug back in, tightened it down and I'll keep an eye on it. Jim
Decided to drain and fill my gearbox (Ford T9) George Alderman had welded a 1/2" bolt to the top of the drain plug which made it easier to get to. Drained it- well sort of. Didn't really get more than 5-10 cc out of the box. It filled with approx 1/2 quart of Redline MTL. Obviously wasn't empty but certainly not full. When I put the plug back in, it went in easily for probably the first 2-3 full turns. The plug appeared to be going in perpendicular to the hole, not angled. Then it started getting very hard to turn as though it was cutting new threads. Removed the plug and no signs of any new threads on it. Can just see part of the threads in the hole which appear ok. My pinky didn't feel anything sharp on the threads. So- maybe there were threads sticking out on the plug when I went to remove it?? About 1/2 of the threads are in. Anyone with any thoughts or suggestions (other than pulling the engine and trans to look at it!) much appreciated. Jim
Help needed from the community to review a future BaT listing
FE07 replied to Pokey's topic in Cars For Sale
Looks good. I remember Kitcats car from the 7's events. Only thing I see is the name of the dealer in Virginia was Chip Bond (not Lamb). Jim -
C & C at Hunt Valley. That red car next to yours sure does look familiar. Sorry I didn't get a chance to talk to you. Jim
Straight piece is 9 1/4" in length. Curved 26 1/2" in length. Both are 1.26" internal diameter and 1.39" external. Where would one go to have these made?? Thanks, Jim
I have some rusting on the metal piping in my cooling system so I took it apart to have it sandblasted and powdercoated. I saw however on the inside of the tubing some oxidation and thought maybe it would be better to replace this and start fresh. They have rolled, raised lips on both ends. Has anyone ever looked into having replacements made or bought new ones? Thanks for the replies. Jim
Affect of Steel and Aluminum Tariff on New Caterham Kit Pricing?
FE07 replied to Rustler's topic in General Sevens Discussion
wdb- Just received my kit from Newton. When UPS dropped it off (which literally took 3 days from England) they collected $34 which the driver told me were due to tarrifs? I don't know, could've been customs? It's likely to only get worse. Jim -
Two sheets of thin aluminum with some bearing grease between them works well. Just make sure the aluminum is wide enough for the front tires. Jim
WOW! So sorry for your loss. Can't imagine. Jim
I used Bears transport to send an Elan from Austin TX to Baltimore. They are brokers but had excellent reviews on Rennlist. They were easy to deal with and since the car did not start, I did not want a large trailer that the car might need to be moved on and off a bunch of times. They found a 3 car trailer for me and fulfilled everything I asked them to do. You can try them at (847) 810-7641. Ask for Liz. Jim
Does that work for the Elan as well? Jim
Thats pretty impressive Charlie- especially living in NYC! Jim
Posted June 12, 2005 The thickness info is AP vented Front disc 18 mm thick new replaced at 16.4mm Hants (North) and Berkshire Area club site here My racing info site here Above is what I found online. That is all the guys who inspected mine wanted when they signed my car off. Jim
Demoray, I did my inspection quite a while ago and unfortunately I’m not sure if the gas station I used still does inspections. I would tell you to stay away from a larger franchise type of place like NTB, Merchants etc…. I don’t know anywhere to send you down in Millersville. I looked online. Try- https://97automotive.com. Just looks like somewhere that may work. Call them first and ask if they have any problem inspecting a Caterham. Hope it helps.
My suggestion for dealing with MD red tape is to talk to some of your car guy friends and find an inspector who is "car friendly". I registered mine about 9 yrs ago but all my inspector wanted to know was the min. thickness of the front brake rotors. I did take it one place first where I thought they would happily inspect it and they gave me MULTIPLE BS reasons why they couldn't inspect it. Jim
Legs, That mint looks nice! Look forward to seeing the build. Jim
Great seeing everyone over the weekend again and chasing each other on track. It's always nice to see people who have come down just to look at the cars and decide if they want to pull the trigger on a purchase. Love what they've done to turn 1. It's now basically makes turns 1 & 2 into one big sweeping turn with a blind track out over turn 2. The weather on track held out great. I left around 3:00 on Sunday and 8 miles west of the track, it was pouring and really windy. Thanks to Mike and Tom as always for organizing! Hope to see everyone again next year. Jim
2024 Annual HPDE Hosted by NJMP Drivers Club - September 6/7, 2024
FE07 replied to Croc's topic in National Events
I'll be rolling in early Friday AM. Look forward to seeing everyone. -
All signed up and ready to go. Crawled under the car to nut & bolt and found 6 rivets missing from the floor on drivers side!! Repaired with some stainless rivets instead of the aluminum ones that were there. That should fix it but I'll keep an eye on it. The harness won't keep me in the car if the floor falls out. See everybody Friday AM. -
Well- not sure what it was but it seems to have resolved with driving the car around. Might have been the clutch disc stuck to the flywheel and driving it around freed it up? Thanks for the suggestions.
Guys- got in the car today for a blat and couldn't get the car into reverse. Lots of grinding gears. The clutch is hydraulic. When I last had it with George Alderman in Wilmington,DE- he adjusted the clutch so that it had about 2-3 inches of pedal travel in total directly off of the firewall. It's been this way for the past 4 years. Made it super easy to heel/toe quickly. I have noted recently some difficulty at times getting into 1st and- have to push down more firmly on the shifter to get into reverse. Checked fluid- maybe 2 mm down. Adding fluid didn't make any difference. I know there is some adjustment for the push rod into the clutch master cylinder. How would I know if it's something with the slave cylinder? Thanks!
Guess just luck of the draw. I had multiple problems with EGR coolers and catalytic convertors on my Touraeg. All covered under warranty however. I know multiple people who have owned Cayenne diesels without those issues. Who know's? Engine is the same as the VW although the trans is different and have never heard of any issues with that on the Cayennes. It pulls my trailer and 7 like they're not there. Probably about 4,500 lbs.
Recently bought a '16 Cayenne Diesel with 95K miles which was CPO'd. That means 2 years of extended warranty from Porsche. I previously had a Touraeg TDi which went back to VW with the diesel recall. Both tow great and and the diesel gets close to 30 mpg. Should last for quite a long time. I'd look for a VW Touraeg TDi as well. Will be less expensive than a Porsche, drive similarly and with the higher end models, be just as nice inside. BAT has had quite a number of Cayenne diesel's within the past 1-2 years. Touraeg TDi's as well. Can at least get an idea of what's out there.
Just like the second youtube video shows. That's how you can add in a bolt in option and adjust it to fit.
