sagamore
Greenville, SC
Se7en
Westfield 7 (pre-lit)
I have a Smiths mechanical tachometer running off the camshaft. It required modification to the front cover and to the camshaft retaining nut. This in turn requires modifying the rocker cover because the original crankcase vent is lost. It's pretty cool in a luddite sort of way, but a Stack chronometric would have done the same thing tapping off the coil signal.
My suggestion would be to post your problem on the MG forum (LINK). Those folks deal with SUs all the time.
Bart, Take a look at these from Holden (link) if you are looking for the Lucas type switches.
In addition to the earlier posts, I would recommend that you try the MG Experience's Spridget website (link). You probably have, but make sure that both carbs have oil in their dashpots. I normally use 20W-50 in mine.
The A-Series gearbox has, as the previous posts state, an unsynchronized straight-cut first gear. It also uses engine oil for lubrication. Most use the same oil that they put into the engine while some prefer a nondetergent 30wt.
WTB Coolant fill neck for S2 Seven America
sagamore replied to RacerX's topic in Parts For Sale / Wanted
Here is where I bought the one for my car: http://www.xtraspecialsevens.co.uk/swirlpot.html -
Looking to purchase first Seven - advice on Westfield
sagamore replied to David Hansen's topic in General Sevens Discussion
I have a very early pre-lit Westfield with the Sprite/Midget running gear. I am 6’ and around 190# and I fit well into the drivers seat. My car uses the front suspension uprights, hubs and brakes, steering rack, engine, gearbox, prop shaft, and rear axle assembly. The mechanical parts are available since they come from a car with a suspension and running gear that was mostly unchanged for a dozen or more years. Engine parts are readily available and other than a lawnmower it couldn’t be simpler to work on. I would recommend the Midget section of mgexp.com for information and resources on the running gear. The only drawback is the transmission’s lack of synchros on the first gear — selecting it should only be done while stopped. However, the A-Series is a long-stroke engine and produces enough torque at the lower end of the rev range that is really isn’t a problem. Just be aware of it the first time you drive the car. -
Proposal for a new 2021 Sevens HPDE in SC - Gauging interest
sagamore replied to Croc's topic in National Events
Maybe I can have mine back together by November or December. It would be a shame to miss something this close to home. -
sagamore replied to Croc's topic in Cars For Sale
I truly didn't know they existed. Every A-series ribcase I've used have only had syncros for gears 2 through 4. -
The nuts are available from Moss (link). I believe in your case it would be part #5 in their illustration.
Contact Hap Waldrop at Acme Speed Shop (864-370-3000). He's a great source of information. Just give him a phone call. (I'm not sure of piston height, but I think the 998 piston should work with an overbore.)
If the rotation doesn't work, then get out the drill.
Could it be Whitworth? (link)
To those that have Brooklands aeroscreens
sagamore replied to sagamore's topic in General Sevens Discussion
Thanks for the replies. My next decision will be to whether or not drill into the scuttle.
