SENC
Everything posted by SENC
  1. Is it hesitating on WOT between idle and 3k, or on gentle acceleration, or both?
  2. At risk of being called soft like the Caterham lads, I've upgraded my fuel gauge and added some rain protection for when not moving.
  3. SENC
    New Build
    So we need to hear more about your video consultant's advice, the video and audio are quite good.
  4. While the guys with new toys were out adjusting their vibrating day/night mirrors and plugging in fuel injectors, I made progress in my analog world. Removed the bushing with a hacksaw blade (slow and tedious work to avoid damaging the end cap) and made the brush removal simple by drilling them out. Cleaned everything with CRC electric terminal cleaner and about ready to start putting things back together.
  5. SENC
    New Build
    What's next, power steering!?! Looks like a great day!
  6. Have been accumulating bits to rebuild the starter for my Seven - a Lucas M35G-1. I got lucky and found a NOS armature so don't have to try cleaning up the old one on my wood lathe. Would love some advice from those of you who've rebuilt these before - both any general advice and tips but also have a few specific questions: Any recommendations on removing the drive end bushing? Also need to clean up the body. The coils look just fine, can't think of a good reason to dismantle further. I assume a bath in kerosene or mineral spirits is the best path and wouldn't hurt anything inside? Last, any guidance on removing and replacing the brushes? I plan try to desolder them but not sure how crammed in that tube they are nor how to work the replacements back in.
  7. https://bringatrailer.com/listing/2009-lotus-caterham-super-seven/ not mine, but timely.
  8. Well, the original pushbutton "manual solenoid" under the dash, but not a coil-solenoid.
  9. Fortunately the ring gear looks ok, at least what I can see through the "window": It is an M35G-1 starter, built in 6/65 so probably the right/original one for the car. I'm going to start searching for parts for a rebuild. Didn't look too bad internally when I took it apart for quick inspection, but definitely well-used.
  10. No more playing and testing today, couldn't get the engine to turn over though starter clearly ran. Wonder why...
  11. Similarly, as I've watched solar farms sprout where pine farms and corn/bean/tobacco fields once were, I've wondered about the cost of cleanup in 20-25 years. I suspect one day we'll get there with renewables, but I'm not convinced we're there yet.
  12. Not defending the valuation (I think it is absurd), but EBITDA is a profitability measure not a revenue measure, rights? With $3b in EBITDA that puts them at a valuation over 75xEBIDTA, crazy territory in my opinion particularly given their track record. GM has 3-4x that much EBITDA and trades at 6xEBITDA (don't think I'd buy that, either). In my opinion this is a pure speculative bet that Tesla will do what Amazon has done. Amazon now has well over $30b in EBITDA and though still highly valued (over 30xEBITDA) it is down from prior years where it was trading at well into the 100s times EBITDA - in essence it has finally grown profitability to begin to match its value. If Tesla can do the same, though overvalued now it will look cheap in the future. I'm not making that bet.
  13. As is so often the case with old cars, messing with one thing to fix another just leads to problems. In this case, trying to clear the "new" breather draft tube I crossthreaded the connection back to the fuel pump so when I cycled the starter to get it pumping it sprayed gas. Though I had an old one (from my Elan) and a spare gasket in my toolbox as an emergency backup, when installed the old pump it filled nicely to the carbs, then promptly began leaking (old glass bowl gasket had hardened). So a couple weeks of waiting on parts, but finally carved out a couple hours on Saturday and got it put back together and running, and started testing different idle jets and main wet/dry jets. Got a great idle, tips in very well at WOT above 2k rpm, and pulls like a train above 3k rpm. Just a little stumble when hitting WOT below about 1800 rpm, but plan to tweak a little more. This is also still on the Bosch distributor, about which I know little about the advance curve built in - but now that I have it close I'll switch over to the rebuilt original Lucas and see what fits the engine better. I realize it doesn't have the hp of the current crop of Sevens, but it really is an amazing little car, you just can't help but smile everytime you put your foot in the accelerator.:driving::driving::driving: Makes me sad I waited this long for a Seven!
  14. This thread needs pictures!
  15. https://www.ebay.co.uk/itm/Lotus-7X-Independent-rear-race-clubman-Magnesium-everything/303600659642?hash=item46b0026cba%3Ag%3AtCsAAOSweh5e7Kc0&LH_Auction=1&fbclid=IwAR1CIuMWoZCH2CqoVDt-tRBJYsTxF6Om4Ad_CaPzSJElKtx63wcko6YQes4
  16. Well covered by the last 2 posts. Here is a snippet from Ortenburger's Legend of the Lotus Seven on the topic:
  17. Looks great John! Frustrating when 1 bolt that should be there is not, I sure know that feeling!!!!
  18. Between replacing old with new mixture screws and a bit of ezturn fuel lube, I seem to have knocked most of the afterfire. Unfortunately, I haven't been able to do much experimenting with different main fuel/air jets or idle jets to find the best fit for this engine due to a cracked neck in my swirlpot (revealed as a nice vertical spray when I removed the thermostat and made the swirlpot to head connection leakproof). Mick Beveridge at XtraSpecialSevens makes a spot-on replacement, which I hope to have in hand this week. In the meantime, I got my draft tube and elbow installed - had to replace an oddly bent SS fuel pipe with a piece of cunifer to keep them from fouling, and the original breather in my engine isn't a perfect fit so probably not intended for the elbow, but with a little rtv I think it will work (will be better than spraying mist straight up, regardless, will see whether enough draft to pull air and gases out). I may change to a later Cortina/Capri breather "box" if this doesn't work as I hope.
  19. Thanks for the civil dialogue, Shane and Mike, not common these days and I'm learning from both of you. Thank you.
  20. Great looking Seven!
  21. With just a little common sense and respect for others, I believe we could be doing a lot more than we're doing AND have fewer cases and spread. Good on your midOhio group.
  22. ...but only good if you're positive earth
